AC problem.. lack of freon?
Old Jul 2, 2005 | 03:35 PM
Ha7chB4cK's Avatar
Default AC problem.. lack of freon?
Well guys I have a problem... my AC is not blowing cold air.. could it be anything else but the freon? And I know the ac is activating because I can turn on the fan and Ill feel the ac come on when I trun the power on.. if that even matters or makes sense lol lol. I drive a 97 civic dx by the way
Old Jul 2, 2005 | 06:34 PM
.Ry's Avatar
.Ry
Default Re: AC problem.. lack of freon? (Ha7chB4cK)
Well first is it blowing hot air or luke warm air? Well if its blowing hot air you have a leak somewhere...if its not hot but a mid temp than its prly just your system needs a recharge....I work at Sears Auto take it there and they will test it for free and tell you if the air blowing out is to hot...make sure you tell them to tell you before they recharge it so you can find somewhere cheaper to recharge it. Any questions PM me.
Old Jul 2, 2005 | 08:47 PM
kkim's Avatar
is your a/c compressor in the engine bay cycling off and on?
Old Jul 2, 2005 | 08:59 PM
_Spugen_'s Avatar
ahem....Check the sig if you end up needing parts..
Old Jul 2, 2005 | 09:18 PM
axxiom's Avatar
You probably just need R12(freon that doesn't kill). My AC was acting the same way and I just needed a recharge. It's a good thing to do every 30,000 or depending on how often you use the AC.
Old Jul 3, 2005 | 10:40 AM
Ha7chB4cK's Avatar
Default Re: AC problem.. lack of freon? (kkim)
I dun even know, I havent really been noticing. Although I really think its just the freon... I hope so atleast... But I do know that towards the last few months its slowly been getting hotter and hotter, and now its just unbearable lol.
Old Jul 3, 2005 | 11:44 AM
kkim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ha7chB4cK &raquo;</TD></TR><TR><TD CLASS="quote">I dun even know, I havent really been noticing. Although I really think its just the freon... I hope so atleast... But I do know that towards the last few months its slowly been getting hotter and hotter, and now its just unbearable lol.</TD></TR></TABLE>
If you don't have a leak and the a/c system has not been opened up, you can just recharge your system w/ r134 from walmart/ pep boys, etc. Get a kit (about $30-40) that includes a gauge and refill the refrigerant from the low side of the a/c system. read the instructions.
very simple to do or go to this link to get more info on how to. use the Screw-in Can Tap Dispensing method in the link
http://www.id-usa.com/how_to_recharging.asp
good luck... being w/o a/c sucks!
Old Jul 3, 2005 | 01:35 PM
Ha7chB4cK's Avatar
Yea man, tell me bout it... ill definitely give that diy a try... imma have it checked for free first tho just to be sure it just needs a refill heheh
Old Jul 3, 2005 | 10:07 PM
underb00steg6's Avatar
hopefull you just need a recharge?
Old Jul 3, 2005 | 10:22 PM
Morning Call's Avatar
proly a recharge
freon is just liquid nitrogen.. and obviously anything that produces cold will get warmer after time
Old Jul 3, 2005 | 10:28 PM
kkim's Avatar
Default Re: (Morning Call)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morning Call &raquo;</TD></TR><TR><TD CLASS="quote">proly a recharge
freon is just liquid nitrogen.. and obviously anything that produces cold will get warmer after time</TD></TR></TABLE>
Wrong....
In 1928, Thomas Midgley, Jr. aided by Charles Franklin Kettering invented a "miracle compound" called Freon. Freon represents several different chlorofluorocarbons, or CFCs, which are used in commerce and industry. The CFCs are a group of aliphatic organic compounds containing the elements carbon and fluorine, and, in many cases, other halogens (especially chlorine) and hydrogen. Freons are colorless, odorless, nonflammable, noncorrosive gases or liquids.
Revolver123
Honda Civic (2001 - 2005)
Jun 12, 2008 03:08 PM
JDMDC295
Aug 18, 2007 07:49 PM
dhatb0ijohnny
Aug 8, 2007 06:20 AM
