Tire Rack Camber Bolts
either call them and ask, or you can look online for other stuff..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa »</TD></TR><TR><TD CLASS="quote">You can probably find this kind of stuff locally.</TD></TR></TABLE>
maybe he cant find high grade bolts locally.. we special order a lot of our stuff for that reason.
If your rear is dropped around 2-2.5", just use your stock camber bolts and add two washer on each bolt and call it a day because the stock bolts are long enough to hold 2 washers. Also remember to use thread lock on the bolts; don't want anything to come loose when running on the street and highway.
Slammed Ek9
10
Aug 8, 2005 10:15 AM
Fuster_Cluck
17
May 17, 2002 10:43 AM
