:::whats the BEST N/A oem setup:::: (opinion)
I have had this on my mind the last couple of days im i guess im finally going to post it: here it is; If you had your hands on ANY oem b-series parts (tranny, cams, pistons, block ect...) What would you build? Now remember ONLY oem honda B-series parts:
Post up what you would piece together
Remember this is an all motor build
here is what i would do w/ my little knowledge!
b16 head
ctr cams w/ dual valve springs
over sized ctr pistions
B20 block
type R tranny w/ LSD!
** my build would be going into a teg so i picked the b20 block for torque**
Im not an expert so i really dont konw what crank and the minor things like water pump ect.. but hopefully yall can fill in the gaps, THANKS and post some up im VERY curious
b16 head
B20 block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">Didnt omniman do this and make like 230+ whp?</TD></TR></TABLE>
dont know but i think it would be a very sick set up!
anyone else have any input
this would be my set up for an all motor oem part only(money will not be considered an issue)
type r head with all the type r lma's in it.(milled for high comp.)
ctr camshaft
type r IM
type r bottom block with ls crank(89mm)
block will be over bored to 81.5mm
oversized ctr piston
those will be the main thing... you get the idea.
ctr camshaft
type r IM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious »</TD></TR><TR><TD CLASS="quote">this would be my set up for an all motor oem part only(money will not be considered an issue)
ctr camshaft
type r IM
those will be the main thing... you get the idea.</TD></TR></TABLE>
ok kool! thanks for the imput and i didnt know that oversized ctr pistions wouldnt fit into a b20
ctr camshaft
type r IM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">Actually to answer your question a K20 would be the best OEM setup. </TD></TR></TABLE>
yeah but i was trying to narrrow it down to just b-series parts b/c they are cheeper and easier to find!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff »</TD></TR><TR><TD CLASS="quote">yeah but i was trying to narrrow it down to just b-series parts b/c they are cheeper and easier to find!
Not really cheaper when you think about it.
</TD></TR></TABLE>Not really cheaper when you think about it.
freakin
Jul 11, 2005 08:03 AM
NinetyTwoHB
21
Mar 23, 2005 05:24 PM
