Turbo coupe lagging???need help
Old Jul 2, 2005 | 09:18 AM
oem_dc2's Avatar
Default Turbo coupe lagging???need help
Modified by BoostedTeggy at 1:37 PM 8/2/2005
Old Jul 2, 2005 | 09:24 AM
SPOOLINmatt's Avatar
Default Re: Turbo coupe lagging???need help (BoostedTeggy)
TUNE IT, it will all be better then.
Old Jul 2, 2005 | 09:47 AM
oem_dc2's Avatar
Default Re: Turbo coupe lagging???need help (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">TUNE IT, it will all be better then. </TD></TR></TABLE>
you think so? either way nobody likes to tune with Greddy Emanage in so cal .
Old Jul 2, 2005 | 09:50 AM
Quad-Damag's Avatar
how u like that ssautocrome manifold, maby it has a crack or a leak or somethin
Old Jul 2, 2005 | 09:53 AM
oem_dc2's Avatar
Default Re: Turbo coupe lagging???need help (Quad-Damage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">how u like that ssautocrome manifold, maby it has a crack or a leak or somethin</TD></TR></TABLE>
its very good quality. we checked for leaks on mani and piping and nothing, could it be detonation?
Old Jul 2, 2005 | 10:00 AM
Marlon88's Avatar
RC440`s on B16 and only 6psi , I think that you are running rich in fuel . That`s why in the lower RPMS it studders because there is way to much fuel .
Try go to tuner and see what`s going on with the Air/Fuel ratio , maybe he can set the fuel pressure regolator a bit lower ...
Old Jul 2, 2005 | 10:35 AM
oem_dc2's Avatar
Default Re: Turbo coupe lagging???need help (Marlon88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marlon88 &raquo;</TD></TR><TR><TD CLASS="quote">RC440`s on B16 and only 6psi , I think that you are running rich in fuel . That`s why in the lower RPMS it studders because there is way to much fuel .
Try go to tuner and see what`s going on with the Air/Fuel ratio , maybe he can set the fuel pressure regolator a bit lower ... </TD></TR></TABLE>
the car has always ran rich. i guess we need to find a tuner
Old Jul 2, 2005 | 10:36 AM
urbansi's Avatar
^^i agree, but then again why would it just start to bog, if there was too much fuel in the first place it would have done it the whole time
Old Jul 2, 2005 | 10:39 AM
Marlon88's Avatar
Default Re: Turbo coupe lagging???need help (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">^^i agree, but then again why would it just start to bog, if there was too much fuel in the first place it would have done it the whole time</TD></TR></TABLE>
Because when the boost kicks in the air/fuel ratio will change because of more air being sucked in the motor, that`s why at hi RPMS the engine will run better
my opinion is to go to a tuner and try to set the fuel lower on the low RPMS .
Old Jul 2, 2005 | 10:44 AM
oem_dc2's Avatar
that makes sense. before boost too much fuel is being dumped, once in boost the motor burns the fuel faster.
Old Jul 2, 2005 | 02:15 PM
sohcvtec1995's Avatar
What FMIC is that?
Old Jul 2, 2005 | 03:47 PM
SuperTeg95's Avatar
Default Re: Turbo coupe lagging???need help (sohcvtec1995)
off topic: what front spoiler is that?
Old Jul 2, 2005 | 05:29 PM
oem_dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">What FMIC is that?</TD></TR></TABLE>
Spark Racing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">off topic: what front spoiler is that?</TD></TR></TABLE>
i think its type R cf
Old Aug 2, 2005 | 08:57 AM
sprayedcrx's Avatar
what size ic piping r u using if its to big it will lag especially on that amount of boost
for a b16 on that amount of boost you should use 2" piping
b00stedbyFastrax
Jun 5, 2006 02:42 PM
prostreetonline
55
Dec 8, 2004 11:17 PM
Raunch
Sep 28, 2004 11:55 AM
Universal Magnetic
May 27, 2004 04:09 AM
B18CRacer
Apr 28, 2004 12:41 AM
