leakage in the car
Old Jul 2, 2005 | 06:13 AM
leono's Avatar
Default leakage in the car
My crx has a serious leak when its rains coming from the tail lights area and somewhere on the passenger side floor. anyone ever had similar problems of any water leaks when it rains.need some advice
Old Jul 2, 2005 | 07:49 AM
4runner's Avatar
Default Re: leakage in the car (leono)
crx glitch
Old Jul 6, 2005 | 02:49 PM
hotimportcrx's Avatar
Default Re: leakage in the car (88HaveFun)
yup
Old Jul 6, 2005 | 03:18 PM
CRX Toad's Avatar
Congrats you have a True CRX!!! Welcome to the club.
If you search a little on the CRX/EF forum you will find a lot of good posts.
Old Jul 6, 2005 | 03:28 PM
90sedan's Avatar
It may be leaking in through your rear tail lights. If the puddle of water occurs in that general area its a good start. To fix it you'll need to replace the tail light gasket.
Old Jul 6, 2005 | 04:01 PM
ne3ek's Avatar
Default Re: (89-civic-DX)
ya mine leaks... EVERYWHERE. i need another shell ):
Old Jul 6, 2005 | 04:44 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89-civic-DX &raquo;</TD></TR><TR><TD CLASS="quote">It may be leaking in through your rear tail lights. If the puddle of water occurs in that general area its a good start. To fix it you'll need to replace the tail light gasket. </TD></TR></TABLE>
this happened on my hatch. $60 for new gaskets from the dealer.
Go to a specialty hose shop and request some 1/8" neoprene gasket material. 2 ft is more than enough. Costs about $5.
You'll need a utility knife, sharpie, hammer, and a few 3/8" copper couplings from home depot.
Make a pattern of the gasket and cut to size. Put the new gasket on the taillight and make tiny cuts where the threads need to penetrate. Reinstall the taillight and tighten the bolts handtight.
Remove the tailight. Use the 3/8" couplings as a hole punch. You'll see exactly where you need to make your holes. Reinstall the tailights and check for leaks.
Old Jul 7, 2005 | 09:16 AM
zccr-xsi's Avatar
yea my **** leaks too but it leaks somewhere round the hatch.
Old Jul 7, 2005 | 09:48 AM
Its me DUB's Avatar
Default Re: (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
do this
or some easy fix that i heard once is soak the old gaskets in warm-soapy water for about 15 minutes and let them dry in the sun. I guess you could try that first...
Old Jul 7, 2005 | 12:06 PM
Twilight's Avatar
Default Re: (doitdub)
I ordered new taillight gaskets. 36€uros per one. Expensive, but OEM...
CR-XSI91
Sep 25, 2012 10:02 PM
toolbox21
May 25, 2009 08:00 PM
vega_ROCKS
Dec 18, 2008 12:19 AM
stevescivic
Sep 15, 2006 06:48 PM
TiredToyotaDriver
Feb 21, 2006 05:53 AM
