maybe alternator going bad?? car no start.
Old Jul 1, 2005 | 11:05 PM
c for sea's Avatar
Default maybe alternator going bad?? car no start.
hey all. I drove my car around, no probs. parked it and came back to start.. now, i can hear my fuel pump whirl but I don't get the cel along with it. actually, i get no lights whatsoever. The only light that comes on is the battery light on the cluster. car will crank but it seems like battery is not strong enough to turn over. i also noticed my clock doesn't come on now.. alternator bad?
Old Jul 2, 2005 | 04:10 PM
EF_9's Avatar
mhmmm yes alternator or dizzy rotor
Old Jul 4, 2005 | 06:37 AM
b18_crx's Avatar
Default Re: (EF_9)
CRX? HATCH? SEDAN? MOTOR SWAP? OBD-0 OBD-1.......NEED MOR INFO MAN.......IF MOTOR WAS SWAPPED OR WORKED ON, CHECK GROUND CONNECTIONS............HAPPENED TO ME ONCE WHEN I SWAPPED TRANNY IN MY CRX
Old Jul 4, 2005 | 06:47 AM
Flexin_B18's Avatar
Default Re: maybe alternator going bad?? car no start. (c for sea)
is the belt tight and on track?
good luck though man
Old Jul 4, 2005 | 09:43 AM
Nerologic's Avatar
Default Re: maybe alternator going bad?? car no start. (Flexin_B18)
Turn on the car some how, when the car is on disconect the battery if the car stays on ur alt is good if it turns off ur screwed..
i have an alt too, but i wont be home until next tuesday
how are the fuses? under the dash and engine bay?
also check out that ghetto fab wiring for any loose ends and while u are at that check your grounds...
Old Jul 5, 2005 | 08:24 PM
c for sea's Avatar
ok, thanks guys. alright then nerologic, hit me up when you get back homeboy. house is all to myself starting tomorrow. bloop bloop
Old Jul 8, 2005 | 09:15 AM
Nerologic's Avatar
Default Re: (c for sea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c for sea &raquo;</TD></TR><TR><TD CLASS="quote">ok, thanks guys. alright then nerologic, hit me up when you get back homeboy. house is all to myself starting tomorrow. bloop bloop</TD></TR></TABLE>
hey faggie check ur PM
ScalCG6
Mar 28, 2019 04:56 PM
92civic_hatch
Feb 6, 2009 06:02 PM
SlammedDC2
16
Dec 24, 2006 06:55 PM
HONDRETTI
Jun 22, 2005 12:00 PM
boosted k20
Jan 7, 2005 02:32 PM
