ABS Light Help Wanted ------>
Old Jul 1, 2005 | 09:20 PM
mike70845's Avatar
Default ABS Light Help Wanted ------>
ok heres how it goes. i start my car up after it is completly cool say after it sits overnight. it runs fine good normal acceleration with wot. after it warms up to temp and i turn my car off and back on and the engine is still somewhat warmed up my abs light stays on and the car runs real shitty. lagging acceleration and slower. any ideas what this could be?
Old Jul 2, 2005 | 12:05 AM
dcdos's Avatar
Default Re: ABS Light Help Wanted ------> (mike70845)
I have the same problem with the light coming on but it does it everytime I turn the car on and it stays on. Also for about a minute after I turn it on it kinda makes a buzzing sound and if I step on the brake it gets louder... I still don't know what it is... Yours seems like it just might be a sensor that's bad. I'm not an expert but abs is antilock brake system and I wouldn't know why your car would run like that at those rpms or even act weird like that at all. Like I said u might just have a sensor out on that abs light and that other problem could be something simple as spark plugs or get a fuel injection cleaning. Try the small stuff first homie. Good luck.
Old Jul 2, 2005 | 12:09 AM
NuclearB18B's Avatar
Default Re: ABS Light Help Wanted ------> (dcdos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcdos &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem with the light coming on but it does it everytime I turn the car on and it stays on. Also for about a minute after I turn it on it kinda makes a buzzing sound and if I step on the brake it gets louder... I still don't know what it is... </TD></TR></TABLE>
i have that same problem. but mine doesn't buzz anymore...i think it died. when i pull the code, i get, abs code #1. (pump motor overrun) i think i'm just going to take the abs light bulb out so i don't have to look at it anymore.
Old Jul 2, 2005 | 12:55 PM
mike70845's Avatar
i already changed the plugs and the injectors shouldnt be bad. ill check to see what code im throwin
Old Jul 2, 2005 | 01:08 PM
kchungb17a's Avatar
Default Re: (mike70845)
check your alternator and battery. low voltage can cause lights to turn on and cause poor acceleration/power.
raene
May 30, 2013 03:13 AM
hondaracin24
Feb 27, 2006 12:16 PM
LSracing94
Aug 29, 2005 06:23 PM
Hawkeye
Sep 25, 2003 09:07 AM
WeSsCyDeR
Oct 24, 2001 03:49 AM
