Noise From Suspension
hey guys, recently i've been hearing a screech/squeek noise everytime i hit a dip or do a hard right turn, the sound is only coming from like the right rear side. wat could this be? need some help please
forgot to add that this is from stock suspension on a 94 gsr.
thanks
forgot to add that this is from stock suspension on a 94 gsr.thanks
so i should replace the bushings? how much do bushings cost and where can i get em, and are they easy to install or have a shop do it? if a shop does it how much would labor be?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggysue »</TD></TR><TR><TD CLASS="quote">so i should replace the bushings? how much do bushings cost and where can i get em, and are they easy to install or have a shop do it? if a shop does it how much would labor be?
thanks</TD></TR></TABLE>
Some bushings needs to greased, some don't, some need to be replaced if the dry rot or are damaged through years of use, those type need to be pressed in with a hydraulic press. Which shops have.
Inspect the bushings for wear and tear. It could just be the upper hat bushings on the coil spring that is causing the sound.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">bushings might need replacing.
Yup, happened on my EJ1 and my brothers DA9, new bushings fixed both our squeeks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">
Yup, happened on my EJ1 and my brothers DA9, new bushings fixed both our squeeks.</TD></TR></TABLE>
how much did it cost or did u guys do it urselves?
Alot of times a squeek is from the upper control arm bushings. They are easy to take out but you have to remove the control arm from the car and pop out the upper ball joint which is often hard to do without ripping the ball joint boot. A press you can get from the parts store for free w/a deposit will probably work to get the ball joint detached, that or possibly a hit with a hammer.
skyjumper_z
11
Feb 17, 2010 01:21 PM
akteamster
Nov 18, 2004 07:48 PM
