new car some questions
Old Jul 1, 2005 | 03:05 PM
Stealthman80's Avatar
Default new car some questions
hey guys, I just bought a 93 accord se with 191kms its in great shape and all, but I have 2 questions the car vibrates when you put it in gear or when your at a light, I took the spark plug boots off and theres a little bit of oil in the 3rd cylinder is that bad? Im gonna get the spark plugs changed. it runs fine otherwise its just really annoying. and wheres the tranny pan so I can do a fluid change? and does it really only take 2.9 litres cause my olds takes like 13 litres
Old Jul 1, 2005 | 03:34 PM
deserthonda's Avatar
Default Re: new car some questions (Stealthman80)
you need to replace the plug seals, remove valve cover, in the inner part there are 4 seals replace those, replace valve cover gasket put all together,,
as for replacing tranny fluid there is a a drain plug you need to get from underneath and yes tranny takes 3 qts of oil ,,,, as for the vibration chk the motor mounts
Old Jul 1, 2005 | 04:10 PM
Default Re: new car some questions (deserthonda)
k ya thanks I just called my dads friend who is a mechanic he said the same thing the valve seal and, I think the vibration is because the spark plugs are shot I just took one out and the elestrode is warn way down, and as for the tranny thanks for the info
foxfai
Mar 31, 2009 08:03 AM
jose310
Jan 12, 2009 01:38 PM
square_1
Jul 21, 2006 11:14 PM
cottonfamily05
May 22, 2005 12:09 PM
LegendKing
Aug 8, 2002 08:16 PM
