Grinding pi$$ing me off
Old Jul 1, 2005 | 10:33 AM
Ricta's Avatar
Default Grinding pi$$ing me off
Yeah whenever i go to about 3k or over and i need to go from 2nd to 3rd or and gear into 3rd it grinds and the higher the RPM the louder and harder it grinds can anyone gimmie some tips on what it might be? If it is my syncro would i have to get a whole new tranny? Thanks in advance
Old Jul 1, 2005 | 10:56 AM
1999all_motoR_teg's Avatar
Default Re: Grinding pi$$ing me off (Ricta)
Sounds like it could be your syncro if only in that gear. Make sure you are clutching all the way in.
If it is the syncro you can have it rebuilt with a new 3rd and 4th, I believe they come in pairs.
Old Jul 1, 2005 | 10:59 AM
Ricta's Avatar
Default Re: Grinding pi$$ing me off (1999all_motoR_teg)
alright thanks
Old Jul 1, 2005 | 11:11 AM
nightrider's Avatar
a tranny fluid change wouldn't hurt to do especially since you're noticing these symptoms. gm syncromesh works really really well, but that's only the friction modified stuff. HOnda MTF would help too.
Old Jul 1, 2005 | 11:17 AM
Haleiwa-Brando's Avatar
Default Re: Grinding pi$$ing me off (nightrider)
Isn't the 3rd gear syncro the one that always tends to go out first in Hondas? (rubs goat hairs on chin....)
You should get that fixed before it leads to the requirement of you purchasing a transmission and/or clutch/flywheel.
Old Jul 1, 2005 | 11:25 AM
kaiba's Avatar
I have that same problem too. It will grind over 1500rpm from 2nd to 3rd. Would it be cheaper to buy a new tranny or have it fix.
Old Jul 1, 2005 | 12:31 PM
Bbasso's Avatar
Sounds like you need some of these :
call them up, I did and was completely shocked with the price and quality. Now I use them and service was on point too
http://www.gear-speed.com/deta...nchor
Old Jul 1, 2005 | 01:11 PM
Circuit Star-29's Avatar
Default Re: Grinding pi$$ing me off (Bbasso)
Gear speed is great. For'em
Coreatown
Sep 17, 2008 03:14 PM
elevatethis
41
Nov 24, 2003 12:02 AM
fangtl
Oct 4, 2003 06:19 PM
RTW DC2R
Sep 14, 2003 06:02 AM
