Throttle Body .
Hey guys , I've been sitting here for half an hour going through countless throttle body post & i can't find the answer to my question , Spade just deleted his SOHC upgrade page so I have no help there so hopefully you guys can help answer my simple as question lol .
I'm upgrading to the LS TB but all i want to know is do i need any sensors from the LS engine bay to make the tb work on my Z6 mani or do i just use the sensors on my current z6 tb ?
Just get @ me asap - thanks justin
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
I would suggest getting the TPS sensor from the LS just in case. Otherwise crank away. Now just to clarify this is a teg LS TB your using correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">all the tps are interchangable so it doesnt matter which one u use
but its always nice to have a extra one around just incase u break it or it fails</TD></TR></TABLE>I knew they were all interchangable, the reason I suggested it was because if it was set perfect you wouldn't have to **** with it. Plus spare parts, especially sensors and **** like that is always good to have. Now will you have to do any port matching to the IT MANI?
So come again now why would you suggest him to get a LS one?
Just use the one that you have I have used several different combos of these with different motors..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 »</TD></TR><TR><TD CLASS="quote">I knew they were all interchangable, the reason I suggested it was because if it was set perfect you wouldn't have to **** with it. Plus spare parts, especially sensors and **** like that is always good to have. Now will you have to do any port matching to the IT MANI?</TD></TR></TABLE>
trooper0641
Jul 3, 2004 10:22 PM
