CRX w/ B16a (Parts List)
Old Jul 1, 2005 | 04:30 AM
g2tegsown's Avatar
Default CRX w/ B16a (Parts List)
Hello,
I have a 1989 CRX Si w/ JDM b16a Swap, and I am having a lot of trouble finding replacement parts that for the car. Since most stores online don't list parts based on engines/swaps, I don't know what parts I need. For instance I think you use 90-93 Axles for a CRX with this swap, and lots of parts from a Del Sol VTEC engine. What I am wondering does anyone have a list/website that tells what parts to get for the crx b16a swap from other cars?
Also can I use parts from USDM b16a's (B16A1,B16A2, etc...) like headgaskets, headers, water pumps, etc...?
P.S. I am NOT looking for a website that tells the parts needed for a swap, because some things didn't necessarily need to be changed at that time (Oil Pump, Oil Pan Gasket, etc...)
Thanks Again
Old Jul 1, 2005 | 04:43 AM
Autoworks's Avatar
Default Re: CRX w/ B16a (g2tegsown)
It s in the FAQ section here somewhere, a very long detailed list
Actually someone asked this question last week and a link was posted, just search thru
Old Jul 1, 2005 | 04:46 AM
Furyof4's Avatar
Jdm and usdm b16a's are the same. All gaskets are interchangeable.
Header---Any bseries will fit, b18 header is taller
Oil pump, waterpump---any bseries vtec
Axles---90-93 teg...if you have y1 trans, you need to get a 90-93 teg intermediate shaft so you can use 90-93 teg axles
Dist cap and rotor---90-91 teg
Basically, all replacement parts are available. Just order parts from 94-97 delsol vtec or 99-00 si.
Old Jul 1, 2005 | 04:47 AM
g2tegsown's Avatar
Damn it...
I just searched on b16a on the CRX forum... forgot to do a recent content search. Thanks for the help without the flame
Old Jul 1, 2005 | 10:13 AM
g2tegsown's Avatar
Ok I have searched and I still cannot find the FAQ or the thread with the link, can anyone shed some light on this for me?
Old Jul 1, 2005 | 12:17 PM
JasonEF8's Avatar
for the most reliable parts for the B16 swap use the HAsport or avid B series to EF parts for the axles but everything else honda is fine !
Old Jul 1, 2005 | 12:19 PM
EP3_05's Avatar
https://honda-tech.com/zerothread?id=521434
Old Jul 1, 2005 | 12:25 PM
NikoZai's Avatar
Default Re: CRX w/ B16a (91civic)
http://www.droppedcrxsi.com
everything you need to know..
Old Jul 1, 2005 | 01:30 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=521434</TD></TR></TABLE>
imsebtactular
Jan 10, 2008 03:53 PM
EF_ST@TUS
Aug 4, 2006 01:49 PM
sam385
Aug 23, 2005 04:16 PM
honda civic racer
Jan 11, 2005 05:55 PM
Mochanic
Mar 7, 2003 02:34 PM
