How to build your own class D amplifier (
For the do it yourselfer I thought some of you might be interested in this. http://cache.national.com/ds/LM/LM4651.pdf
To get full use out of it you would need to design a power supply but it will also work with +/- 12V just reduced power output. Under voltage lockout is 10.5V
Build a nice power supply and replace the LM4652 with some different transistors and you could have a powerful amplifier.
Modified by nsxxtreme at 12:59 PM 7/1/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ »</TD></TR><TR><TD CLASS="quote">Joking, right?</TD></TR></TABLE>
No, there is a completely laid out example at the end even the board layout. The circuit consists mainly of just the two IC's. Your looking at $30 worth of parts not counting the boards. Some people like to do things on there own. You could also learn how a class D amplifier works from that documentation. You know how one works you pretty much know how they all work.
There is usually three main sections to an amplifier.
1. pre-amplifier this is where any signal processing gets done. Bass boost, Treble boost, ect.
2. Amplifier - This is where the main amplification gets done.
3. Power supply - This is essentially an amplifier also, it raises the 12VDC up to +30V and -30V the amount depends on the amount of amplification needed.
It doesn't matter if its an A, B, AB, or D they will all have these sections. The paper I linked to is #2 just the amplifier. The Power supply would go to the +Vcc -Vee on the IC.
That paper shows how Class D amplifiers work and why they are as efficient as they are. Instead of being a linear amplifier. They chop the signal up at a high frequency. This is filtered out at the ouput. You will notice a low pass passive filter on the ouput of the amplifier. This removes the high frequency components.
A good view of the sections can be seen here https://honda-tech.com/zerothread?id=1267955
From left to right Pre-amplifier, Amplifier, Power supply
RsxType-Stitch
16
Sep 7, 2005 07:52 PM
