swap is done.. WONT START!
Old Feb 13, 2002 | 10:31 PM
[626]95-GSR's Avatar
Default swap is done.. WONT START!
finally done with the swap.. we checked pretty much everything. but the damn thing still wont start.. It turns over fine, but it just doesnt fire up. Heres some things im considering.. Checking for spark in the wires.. no spark on start up.
Fuel is a little low, but i think there should be enough to at least start the motor.. ANY suggestions?? help me.. thanks..
Old Feb 13, 2002 | 10:33 PM
RexB16's Avatar
Default Re: swap is done.. WONT START! ([626]Rj-SiHatchy)
strat checking all ur conenctions.
Old Feb 13, 2002 | 10:40 PM
Mugen Dom's Avatar
did u check ur ground conections yet?
Old Feb 13, 2002 | 11:29 PM
balistic CRX's Avatar
Default Re: swap is done.. WONT START! (jdmB18hatch)
what kind of motor did you put in? did you try to check your timing.
Old Feb 14, 2002 | 12:17 AM
CRX-RX's Avatar
Default Re: swap is done.. WONT START! (balistic CRX)
Does the fuel pump turn on when you turn the key forward? If not check your ground on the thermostat housing.
Old Feb 14, 2002 | 09:11 AM
Default Re: swap is done.. WONT START! (CRX-RX)
Fuel seems to be OK.. I took my fuel pressure regulator out and fuel was spraying out.. so im sure fuel is getting to the fuel rail.... ill be sure to make all my grounds are intact.. but i was thinking its something to do with the fact that there is no spark from the plug wires. I tested it.. tried to start the car.. NO SPARK.. im pretty sure im testing it right, a spark should jump from the wire to a ground right?? any other suggestions, i need my so i can go out on a date!! thanks in advance.
[Modified by [626]Rj-SiHatchy, 6:13 PM 2/14/2002]
Old Feb 14, 2002 | 09:48 AM
Blown90hatcH's Avatar
Get another distributor. Did you do a compression test? You sound like you are doing your spark test right.
JAson
Old Feb 14, 2002 | 10:09 AM
Hayasa15's Avatar
Default Re: swap is done.. WONT START! (Blown90hatcH)
I would have to say check your distributor and your grounds.
Old Feb 14, 2002 | 10:11 AM
i havent done a compression test yet.. but i figure since the cam is turning.. it should at least spark.. im leaning more toward a distributor problem.. but i tried using another distributor.. still nothing.. could be wiring problem?
Old Feb 14, 2002 | 12:03 PM
JUNcr-x's Avatar
check your map sensor hook up. I have the same set up and had the same kind of prob. turns out we wired the map 2 the wrong wire in the harness. just a suggestion. also ignition see if +/- are hooked up right. that if U have a coil or MSD..good luck
Old Feb 14, 2002 | 03:46 PM
brad.'s Avatar
Default Re: swap is done.. WONT START! (d16Z6turbo)
well actually, my brothers motor was a z6 but he went back to d16a...so its basically another stock motor, going back in
Old Feb 14, 2002 | 04:03 PM
daniel89civ's Avatar
Default Re: swap is done.. WONT START! ([626]JDM-b16a-EF9)
did you check the batery if it has charge
check starter wiring
fuse box
[Modified by daniel89civ, 5:08 PM 2/14/2002]
Old Feb 14, 2002 | 04:06 PM
brad.'s Avatar
Default Re: swap is done.. WONT START! (daniel89civ)
battery has charge, the motor wouldn't crank if it didn't....
we have 2 distributors
Old Feb 14, 2002 | 04:10 PM
do you hear the sound wen you turn the key
Old Feb 14, 2002 | 04:13 PM
brad.'s Avatar
what sound? the motor tries to turn over
Old Feb 14, 2002 | 04:15 PM
no from the starter
Old Feb 14, 2002 | 04:17 PM
brad.'s Avatar
the starter is fine....it turns the flywheel....no problem there
Old Feb 14, 2002 | 04:18 PM
[626]JDM-b16a-EF9 are you [626]rj-hachy too
Old Feb 14, 2002 | 04:19 PM
brad.'s Avatar
im his brother
Old Feb 14, 2002 | 04:21 PM
in my way back home today at 9:00am i saw your car parked do you live close to cragen
[Modified by daniel89civ, 5:22 PM 2/14/2002]
Old Feb 14, 2002 | 04:28 PM
brad.'s Avatar
yeah
Old Feb 14, 2002 | 04:30 PM
do you have the car in your house the one that does not start
Old Feb 14, 2002 | 04:50 PM
Speed_Ricer99's Avatar
I Had the same problem. I switched the 2 white wires that I had spliced around and it fires now.... Wont stay running, but thats a different problem.
[Modified by Speed_Ricer99, 8:52 PM 2/14/2002]
Old Feb 14, 2002 | 07:11 PM
Mugen Dom's Avatar
Default Re: swap is done.. WONT START! (Speed_Ricer99)
jesus god u guys jis car turns over ok that means everything is good but aint getting a message to make spark some how.
has to be a break in the line from the ecu. trace teh lines make sure they are where they should be. one real question was the z6 running a obd0 or obd1 ecu and dist?
Old Feb 14, 2002 | 08:52 PM
vsual's Avatar
no no no!! the question is...is it throwing any codes???
