Some what long question about MPFI swap......
Old Jun 30, 2005 | 06:31 PM
TwztdSi's Avatar
Default Some what long question about MPFI swap......
OK, here goes......... I just got an automtic 89 DX hatch.....my question is not about the wiring, I think I have that part covered..... I want to put the DOHC ZC motor out of my crx in it. Here is the question...Will I have any problem with the 89 auto tranny bolting to the 91 ZC motor? Also I don't really want to use the stock DX ECU to run the ZC and I happen to have an auto 89 Integra ECU...Will the Teg ECU work to run the car and if so , will any of the wiring be different? I believe that is all I need to know right now..... Thanks in advance for any help you might be able to give me..........
Old Jun 30, 2005 | 07:15 PM
dr_latino999's Avatar
Default Re: Some what long question about MPFI swap...... (TwztdSi)
The Automatic Integra ECU should work. What you want to do is wire up MPFI as you would normally for a ZC and leave all your transmission wiring intact. If the MPFI instructions tell you to re-arrange any of your transmission wires, then contact someone like the good folks at http://www.rywire.com for advise.
Old Jul 1, 2005 | 01:57 AM
gutterslide's Avatar
transmission will bolt right up. auto integra ecu will work (DX ECU won't work anyway). you'll have to do an MPFI conversion (standard for any ZC swap) just don't change the B11 wire on the ECU.
i updated the fourthgenhatch site to include auto MPFI conversion differences.
Old Jul 2, 2005 | 04:03 PM
TwztdSi's Avatar
IF the DX ECU won't work, what ECU would you recommend? Any one better to run it than the 89 Teg ECU? Oh and thanks for all of the input so far.
Old Jul 2, 2005 | 04:19 PM
TwztdSi's Avatar
Default Re: (TwztdSi)
OH and one more question.... Do any of you know if the powersteering pump and all the air conditioning will bolt up to the ZC motor?
Old Jul 2, 2005 | 06:27 PM
PM6 (88-91 Si, EX, 4WD wagon) good, lean
PG7 (88-89 Integra) better, rich
PM7 (JDM ZC) best match, of course
i'm running an auto PG7 on mine.
and, check out http://www.thezcr.com
TwztdSi
Jun 10, 2005 11:09 AM
vegaskurt
Jan 12, 2005 06:23 PM
red97tj
Oct 10, 2004 11:38 PM
SteveeeO
13
May 26, 2003 09:15 AM
saucycivic
24
Jun 26, 2001 07:02 AM
