Installing transmission-How?
Old Jun 30, 2005 | 04:58 PM
PabloDiablo's Avatar
Default Installing transmission-How?
'92 civic dx 1.5, manual transmission
I put in a new clutch. Everything went nice and smooth. Now I've spent two days trying to get the transmission mounted back on the motor. No matter what I do I can't get the input shaft lined up in the clutch disk hole. 12 hours of wrestling with it and nothing...
What's the trick?
I have a floor jack, the car is on jackstands.
Thanks
Old Jun 30, 2005 | 05:00 PM
2.0L EK's Avatar
Default Re: Installing transmission-How? (PabloDiablo)
you made sure to like the clutch up when you tightened down the pressure plate right
Old Jun 30, 2005 | 05:15 PM
kkim's Avatar
are you using a clutch alignment tool?
Old Jun 30, 2005 | 05:27 PM
2.0L EK's Avatar
Default Re: Installing transmission-How? (2.0L EK)
Did you also make sure it was the correct clutch disc for the tranny? Check to see if the splines fit over the main shaft from the tranny
Old Jun 30, 2005 | 05:36 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0L EK &raquo;</TD></TR><TR><TD CLASS="quote">Did you also make sure it was the correct clutch disc for the tranny? Check to see if the splines fit over the main shaft from the tranny</TD></TR></TABLE>
Ya always compare old and new parts before u install. Look at the FAQ/DIY sticky on the top of the forum too. I think there is a clutch how-to in there
Old Jun 30, 2005 | 05:41 PM
I used an alignment tool to make sure the clutch plate was in right. I'll check to see that the splines will line up. Thanks for the help...
mike9571
Apr 15, 2007 10:02 AM
90LSpimpin
Aug 18, 2004 05:16 PM
90LSpimpin
Aug 18, 2004 04:01 PM
incognitoracerr
Mar 26, 2003 09:13 PM
02WRX
Jun 20, 2002 11:23 PM
