Car won't start Agian. Searched. weird symptoms bad ECU?
Old Jun 30, 2005 | 12:06 PM
DIYMIKE's Avatar
Default Car won't start Agian. Searched. weird symptoms bad ECU?
i was driving when my car just dies out of no where. get it home and it cranks wierd because of the sound it makes. i pull the plug and see if i get spark and nothing. this happen to me before and it was usually the distributor, i buy one off ebay and still the same thing!
i get no CEL, i unplug my distributor and try to start it and there is no CEL, i start to unplug my map sensor and different kinds of sensors and it won't throw a CEL. so i think its my ECU. is there a way to test it before i shell out some money for a ECU on ebay?
Old Jun 30, 2005 | 04:15 PM
CivicNewbie's Avatar
Default Re: Car won't start Agian. Searched. weird symptoms bad ECU? (vtecgenocide)
have u checked the ignition coil ? #12 on pic:
Old Jul 1, 2005 | 02:29 AM
DIYMIKE's Avatar
Default Re: Car won't start Agian. Searched. weird symptoms bad ECU? (CivicNewbie)
yeah bro i bought two distributor;s off ebay. and i don't think its the coil. the first distributor looked all rusted inside so i thought i just got a bogus distributor and then i bought one that was in great condition and was off a running car. still the same thing bro.
anybody have some knowlegde to share?
Old Jul 1, 2005 | 03:00 AM
The_Todd's Avatar
Farts in the shower
If you don't have spark that is a place to start. First off, how are you checking for spark?
I would pull out your ignitor and test it with a voltometer...check your service manual (chiltons, helms, haynes etc) for guidlines. If its not your ignitor then I would say a bad plug or possibly a bad plug wire. You can go down the line and check things to determine if something is bad or not. Oh and typically a bad ignitor won't throw an ecu...it just won't start .
Old Jul 1, 2005 | 06:26 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecgenocide &raquo;</TD></TR><TR><TD CLASS="quote">i was driving when my car just dies out of no where. get it home and it cranks wierd because of the sound it makes. </TD></TR></TABLE>
Did the timing belt break? Remove the oil fill cap and look down in there while someone cranks the engine. Do you see anything moving?
Old Jul 1, 2005 | 12:33 PM
DIYMIKE's Avatar
Default Re: Car won't start Agian. Searched. weird symptoms bad ECU? (Chiovnidca)
i used starting fluid and also used a multimeter.
i am going to swap ecu with a friends and see what happens.
Old Jul 3, 2005 | 12:35 PM
DIYMIKE's Avatar
I found out the problem! a friend help me look at the car and when i was testing the distributor again, he told me that my rotor in my distributor wasn't spining. so then i look at the timing belt and sure enough the timing belt was missing some teeth and wouldn't turn over the cams and thats why i wasn't getting any spark because the rotor wasnt hitting the cap.
just thought i post that since nobody really lets you know how they fixed it.
Old Jul 3, 2005 | 01:15 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecgenocide &raquo;</TD></TR><TR><TD CLASS="quote"> so then i look at the timing belt and sure enough the timing belt was missing some teeth and wouldn't turn over the cams
just thought i post that since nobody really lets you know how they fixed it. </TD></TR></TABLE>
Thanks for letting u know. That's almost always the first thing I check when getting a died while driving complaint. One of the quickest, easiest checks that can save so much time.
Carlos Peralta
Jan 13, 2013 05:43 PM
SIC_WIT_IT
Mar 28, 2009 01:46 PM
rodvang
Jan 9, 2008 05:45 AM
InvaderTrax
Oct 15, 2006 05:59 PM
chirp2hrd
Sep 1, 2002 03:26 PM
