Vitara pistons setups...SIGN UP HERE
Old Jun 30, 2005 | 09:18 AM
fjt's Avatar
fjt
Default Vitara pistons setups...SIGN UP HERE
Alright. Im creating this thread for reference and to keep track of all the builds with the Vitara pistons that are running.
Please!!!! Just post your setup if the motor is assembled and running in your car or a friends ride.. Try to keep questions to a minimum since this is only a reference post.
If you want to be here, build your motor!! je je..This thread is to encourage all who has the pistons but have not finished their builds yet. I know there are more than 30-40 members that have bought these pistons.. So there should be quite some setups around.
Everyone who post their setup can edit their posts and update on whats going on with their rides, such as if you re dynoed or added something to the car.
Please post:
*Car:
*Engine:
*Time being built
*Basic setup(BASIC being the key word je je)
*Turbine used and specs if possible:
*Link to your Build threadhere should be all the rest of the detailed info on your builds)
*Type of Engine Management:
*Power results + Dyno Chartwhen u have it available)
*Track times if any and time slip
*any other misc or curious info you want to add from your experience with the build/tunning.
-----------------------------------------------------O--------------------------------------------
That being said.... Im gonna break the Ice
*Car: 1999 Civic Hatchback
*Engine: D16Y7 / Y8 Tranny
*Time being built: Car went out of the shop May of 2004(break in).. Boosted in October of 2004...
*Basic setup: Stock Head,Vitaras,Eagle rods,Love Fab Manifold, Intercooler, 3" DP and Exhaust
*Turbine used and specs: T3 Super 60 , .48 exhaust/.60 compressor. Spools around 3000rpms, Full boost +/- 4200rpms
*Link to Build thread: see signature
*Type of Engine Management: P06 ECU, Uberdata 1.66, dsm 450cc injectors, Walbro 255lph hp
*Power results, boost level + Dyno Chart: 266whp 240lbs/ft @ 18 PSI
Dyno sheet--> http://www.we-todd-did-racing....D.jpg
*Track times if any and time slip: 12.44 @ 111mph , MH slicks 22 X 8, 13" rim
Modified by fjt at 6:31 PM 6/30/2005
Modified by fjt at 6:35 PM 6/30/2005
Old Jun 30, 2005 | 10:20 AM
93turbo16's Avatar
Default Re: Vitara pistons setups...SIGN UP HERE (fjt)
Please post:
*Car: 93 Civic Ex
*Engine: D16Y7 block with a Y8 Head.
*Time being built: Car has 2500 miles on it and counting.
*Basic setup: BMC race Log manifold, super/big 16G, Y8 mani, LS TB, 450 injectors, walbro, JRC 5", Crower I-beams, ARPs
*Turbine used and specs if possible: I believe the exhaust is like a .73 A/R, it is a super 16G exhaust housing, from Hahn racecraft, Big 16G intake side.
*Link to your Build thread: https://honda-tech.com/zerothread?id=1264338
*Type of Engine Management: Uberdata, tuned by me.
*Power results + Dyno Chartwhen u have it available): 231hp and 188Tq, on 14.5 Psi, loose charge pipe.
*Track times if any and time slip: July 23rd.
Zex 59300 cam and cam gear going on this sunday and new lower charge pipes. Will see 20 psi at the dyno, and I will report back as soon as I get the sheet.
Old Jun 30, 2005 | 11:15 AM
Johnyquest's Avatar
Default Re: Vitara pistons setups...SIGN UP HERE (93turbo16)
Dyno can't be posted at the moment b/c of an error w/ WTDR and my account not deciding to activate, so you'll have to hold out.
Setup:
-95 d16z6 in an EX coupe.
-Vitaras / SCAT rods.
-Junkyard (and now blown) t3, tiny .. .42/.48 maybe, from a volvo
-11,000 or so miles on it, boosted from mile 1 of rebuild.
-uberdata + dsm450's, tuned by me
-Dyno'd @ 1 bar, but have boosted up to 18 lbs, accidentally maxxed out boost gauge a few times ... but boost cut is our friend.
Dyno chart is as follows (mental picture, people):
fully spools to 1bar @ 4k rpms, makes ~200 ft/lbs from 4k-5500rpms, then from 5500-7500, steady fall to a final torque @ redline of 150 ... turbo is too small
PEAK torque = 202.5 ft/lbs @ 4500 rpms
PEAK horsepower = 213.1 @ 6k rpms
nice powerband from 4500-7k ...
Turbo is shot ... t3/t04e 50 trim is in the mail. The current turbo just didn't have enough for this motor, so we'll see.
Good luck everyone else!
MATT
EDIT: GOT THE DYNO PIC UP:
The higher tq/hp dyno is the new motor ... he happened to have the dyno of my old stockblock (same motor) setup before it blew still on the comp, so he overlayed them for me. Pretty cool eh?
Modified by Johnyquest at 3:30 PM 6/30/2005
Modified by Johnyquest at 3:31 PM 6/30/2005
Old Jul 5, 2005 | 05:17 AM
fjt's Avatar
fjt
where's G3NR8 setup?
Anyone else..C'mon guys i know there must be more than 3 setups running around
Old Jul 6, 2005 | 06:16 PM
G3NR8's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">where's G3NR8 setup?
Anyone else..C'mon guys i know there must be more than 3 setups running around</TD></TR></TABLE>
Here ya go:
*Car: https://honda-tech.com/zerothread?id=1296381
*Engine: D16Y8 block and head
*Time being built: Took about 7 months start to finish acquiring parts and assembly, and the setup currently has 1000 miles on it.
*Basic setup: Y8 block, Y8 head, Vitara pistons, Eagle rods, 16g turbo, BMC manifold, DSM 450's, uberdata
*Turbine used and specs if possible: Regular 16g DSM (not exactly sure of specs)
*Link to your Build thread: https://honda-tech.com/zero...64462
*Type of Engine Management: uberdata
*Power results + Dyno Chart:Missed my dyno appointment yesterday cause I'm still waiting for my 3 bar map sensor to get here Hopefully I'll be able to go next week. I'm currently running 9psi on the same map from my old motor, and will be using 15 or so daily, and more on the dyno.
*Track times if any and time slip: Nothin yet...
Old Jul 15, 2005 | 08:27 PM
shauniewalnuts's Avatar
bump!
Old Aug 1, 2005 | 11:15 AM
EJ1 wilcox's Avatar
Default Re: Vitara pistons setups...SIGN UP HERE (shauniewalnuts)
Up!
I know there are some more out there!
Old Aug 1, 2005 | 11:31 AM
splitime's Avatar
Default Re: Vitara pistons setups...SIGN UP HERE (EJ1 wilcox)
*Car: Doesn't matter
*Engine: high mileage D16z6, head has zex springs and bottom is ACL bearings and Eagle rods
*Time being built: 5k and still going strong. 155psi across the board about 500 miles ago.
*Basic setup: HF manifold, Audi External gate on manifold for highboost, 14b/td05h with internal gate for daily driving, 2.5in DP right into 3in exhaust, dual dsm SMIC FMIC, 2in into IC 2.5in into throttle body, 450cc injectors, Mountain Dew Catchcan.
*Turbine used and specs if possible: 14b/td05h
*Type of Engine Management: Turboedit, (motor is using d16a6 distributor and all obd0 gear) Wideband street tuning.
*Power results + Dyno Chartwhen u have it available): No clue... might get to a dyno day soon.
*Track times if any and time slip: Possibly the 3rd. Ima run at the 7psi internal gate... 15-18psi external with just the boost retard of -.6 Then dyno time will allow for real ignition timing.
Anyone have the hookup for a big 16g? ie: evoIII 16g.
edit: keep updating overall mileage
Modified by splitime at 12:36 AM 9/1/2005
Old Aug 2, 2005 | 03:02 PM
93turbo16's Avatar
New time atleast for me.
8.4 @ 84 MPH, 2.0 60'
Still on small slicks, on 17psi, untuned, no cam.
Old Aug 2, 2005 | 04:16 PM
nonvtecD's Avatar
*Car: 94 DX coupe
*Engine: D16y7
*Time being built: Motor as about 5K on it since first broken in on boost.
*Basic setup: Stock Y7 with Vitaras. JRC Front Mount, Drag manifold, 1G DSM injectors and BOV etc...
*Turbine used and specs if possible: 48/60 T3
*Type of Engine Management: Uberdata 1.7 tuned by 93TurboB16
*Track times if any and time slip: 14.8 at 94 mph, 8 psi with FTL set way too low and bogging off the line. With a good hookup it could run high 13's with the same boost level.
Modified by nonvtecD at 8:58 PM 8/14/2005
Old Aug 6, 2005 | 09:20 AM
splitime's Avatar
Default Re: Vitara pistons setups...SIGN UP HERE (nonvtecD)
Fellow Vitara users.... anyone want to release aproximate timing degrees for their setups at different boost levels? Don't have time for dyno atm, and street tuning of the timing would be simpler with a psuedo target timing.
Oh, heres the TE map if anyone is interested in looking at it. TE 2.5.5
http://www.xenocron.com/bins/i...oEdit&
Modified by splitime at 12:33 PM 8/6/2005
Old Aug 6, 2005 | 09:24 AM
93turbo16's Avatar
At the moment my numbers are rather low, but I am at like 18 degrees at like 15 psi. And like 23 at 10 psi.
Old Aug 6, 2005 | 06:47 PM
PA MATT's Avatar
Default Re: (93turbo16)
this is for everybody, but 93turbo16 as well since he will be tuning my car. Would this pistons and an sc50 with a .48 hot side revving to 7500-8k make 300whp with these pistons or would it be getting a bit unsafe?
Old Aug 6, 2005 | 08:11 PM
93turbo16's Avatar
It would make it just fine in my opinion.
Old Aug 6, 2005 | 10:18 PM
G3NR8's Avatar
I guess I'll update, although I'm kinda reluctant since I had some problems...
I am currently at 13-14psi. I had a boost leak when I was tuning a couple weeks ago, so we never went past 13psi. I figured it out to be a crack in the manifold (another crack actually). I made about 211hp and around 200tq at 12-13psi. I fixed the leak, and turned up the boost a notch and the car ****** rips ***. I should be going back to get retuned for around 18psi within a couple weeks. I'll keep this updated
Old Aug 23, 2005 | 06:39 AM
Default Re: (G3NR8)
BUMP!
Old Aug 23, 2005 | 07:21 AM
LoSt is BlaCk's Avatar
Default Re: (shauniewalnuts)
i just helped my buddy get his together and in...it should be tuned soon...i hope great thread!!!
Old Aug 23, 2005 | 07:30 AM
tilt's Avatar
Friend's track car I helped build
Car: 1997 Civic HX
*Engine: D16Y5
*Time being built: a couple weeks to order parts, two days to complete build, weekend of practice autox to tune and break engine in.
*Basic setup: stock head, TunerToys rods(SYSC), ACL bearings, ARP headstuds
*Turbine used and specs if possible: DSM T25 ~8psi, intercooled, HF manifold, 2.5 downpipe
*Type of Engine Management: P28, Uberdata 1.7, DSM 450 injectors, GSR fuel pump
Old Aug 23, 2005 | 07:59 AM
boonacka's Avatar
Default Re: Vitara pistons setups...SIGN UP HERE (tilt)
CURRENT PROJECT (...lack of time)
*Car: 1990 CRX Si
*Engine: D16A6 / Si Tranny
*Time being built: Began March 2005 - Finished June 2005, currently no tim to drop into car
*Basic setup: 3angle head, new stock valvetrain, ZC Camshaft, Skunk2 gear, .020 milled, ARP head studs, Vitaras, Eagle rods, ACL bearings, GE block guard, bailhatch shorty manifold, JRC Intercooler, TIAL wg, kteller 3" exhaust
*Turbine used and specs: 50 trim t3/t04E, .50/.63
*Link to Build thread: under construction
*Type of Engine Management: PM6, DSM 450cc, Turboedit, Zeitronix ZT2
*Power results, boost level + Dyno Chart: TBA
*Track times if any and time slip: TBA
some pics
Modified by boonacka at 10:22 AM 9/13/2005
Modified by boonacka at 10:25 AM 9/13/2005
Modified by boonacka at 11:09 AM 9/13/2005
Old Sep 13, 2005 | 06:31 AM
boonacka's Avatar
Default Re: Vitara pistons setups...SIGN UP HERE (boonacka)
any updates from anyone else running this setup
Old Sep 13, 2005 | 06:42 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">any updates from anyone else running this setup</TD></TR></TABLE>
I'm at almost 6k miles on mine and about 16-17psi from my 14b. Still sounds the same and runs great. Once wideband is back the boost will go up and maybe i'll plan some dyno time for ignition work.
Old Sep 13, 2005 | 07:09 AM
boonacka's Avatar
Default Re: Vitara pistons setups...SIGN UP HERE (splitime)
still gets alot of piston slap?
Old Sep 13, 2005 | 07:13 AM
fjt's Avatar
fjt
Im working on doing some upgrades..
*bigger turbo to reach or pass the 300whp mark on a stock Non vtec head
Super 60 on the left..new turbo(t3/t4e 57 trim) on the right
I should be set to dyno in around 2 weeks
Old Sep 13, 2005 | 07:16 AM
fjt's Avatar
fjt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">still gets alot of piston slap?</TD></TR></TABLE>
Its not piston slap!!! Otherwise i wouln't have a motor and the skirt of my sleeves would be totally destroyed..more after each 12 sec run
Old Sep 13, 2005 | 07:26 AM
boonacka's Avatar
i guess just noisy before they expand a little then huh
