88 D16a6 Timing Belt Question
Old Jun 30, 2005 | 06:55 AM
crx_88_si's Avatar
Default 88 D16a6 Timing Belt Question
I was just poking around my engine bay. I saw the slot on the timing belt cover and i took a peek inside.
With the engine running i looked at it again and seen the belt moving (as it should) but I also noticed it looked to be wobbling.. is this normal to have a slight wobble on the belt?
when i revved it the slack went away but when i let off it was even more slacked then tightened up again..
I'll try to get a video of it...
thoughts?
Old Jun 30, 2005 | 07:08 AM
lodo1's Avatar
Default Re: 88 D16a6 Timing Belt Question (crx_88_si)
the tensioner?
Old Jun 30, 2005 | 07:17 AM
HumanResource's Avatar
Well if the Belt hasn't been replaced in a long time, then I can guess it's both theworn belt and the loose tensioner.
Old Jun 30, 2005 | 07:18 AM
crx_88_si's Avatar
that was my first though as well.. but is it normal to have a little wobble in a idling engine's belt?
or a streched belt?
has 50,000km on it. (approx)
Old Jun 30, 2005 | 09:02 AM
bagpipe goatee's Avatar
my old d15b2 with 200 some thousand miles had a broken tensioner, so it had like an INCH of freeplay on the belt. you could make it jump a tooth by hand with the cover off, but driving i kept the cover on, and try as i might, i couldn't get it to jump a tooth, because the cover didn't give it enough clearance. (while trying to get it to jump, i even bounced it off the rev limiter sometimes)
but, still, if it's a motor you care about, replace the belt and tensioner.
i just wanted to see some carnage with that motor, i wanted to kill it before i put my d16a6 in, but it never died. the tranny developed a leak and started to make scary noises, so i swapped it out.
on my d16a6, it had a timing belt replacement about 20k ago, and the belt is nice and tight.
HyperFlow
Aug 2, 2010 01:46 PM
MassCivicMan987
Jun 28, 2007 11:48 AM
MassCivicMan987
Jul 3, 2006 04:25 PM
VTHokie
Jul 23, 2002 07:47 AM
