head gasket
Old Jun 30, 2005 | 05:04 AM
1gEF-8's Avatar
Default head gasket
compression gains if i use a metal y8 gasket on a z6. reading different post i figured out you can remove the middle layer of the y8 gasket to raise comp. with the middle layer removed what gains in comp. can i expect.
Old Jun 30, 2005 | 06:19 AM
manson's Avatar
Default Re: head gasket (1gEF-8)
if i remember correctly its .2 compression raise for every .001 removed.
the middle gasket is .001 i believe.
be very careful removing the rivits...don't bend or kink the gasket.
when removing the middle gasket remember to use copper spray. it helps make a better seal when you reapply the gasket... and if the gasket is not completly straight it will help fill in uneven surfaces.
journeyquest
Sep 3, 2010 12:39 AM
airikkCRX
Jul 2, 2010 02:51 AM
nappyroots827
Aug 3, 2006 10:19 AM
Wes90civic
Jan 19, 2004 11:13 PM
altoid
Feb 7, 2003 06:37 PM
