tach not working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PETEROCK1 »</TD></TR><TR><TD CLASS="quote">my tach recently went out. what to do now? need your help guys! thanks in advance!</TD></TR></TABLE>
it would help to state what car and motor.
how odd... only thing you can do if it's truely the tach is replace the gauge cluster. Junkyard
If it isn't running right as well, your distributor may be the problem.
Check your fuses if other things on the gauge cluster don't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai »</TD></TR><TR><TD CLASS="quote">how odd... only thing you can do if it's truely the tach is replace the gauge cluster. Junkyard
Check your fuses if other things on the gauge cluster don't work.</TD></TR></TABLE>
also could be an Ignitor going bad and make sure none of the wires to the dizzy are damaged
-[95cxhatch]-
Apr 21, 2005 08:12 AM
