Pulling whole harness from my car
Like it ststes above im pullin the entire underdash and engine harnees from my car. it wont start and this is the last step. weve done everything we could to make her run but she wont. So i decided to change the harrness. thinking sum wires may be cut,torn, or fried. Iam in the process of pulling the old one right now. Ill post up sum pics tomorow of the tear down and rebuild up. Any help, advise etc is wanted
Also any others that have done this please chime in, i wanna hear ur guys stroies and such
haha If you're putting in the same exact year/model harness then great. I think there is a way you don't need to remove the dash, pull the seats and carpet to start off with. I think the cabin harness seperates somewhere in the middle so you don't end up taking out the wiring for the tail section. Not sure though.
If you're mixing and matching models and years, good freakin luck
I would have traced the wiring on that engine harness to find what the real cause was instead of just randomly replacing it all...
Troubleshooting Knowledge
Just replacing things at will.
I am currently in the same process and my car is a 91 STD CRX and i got an untouched 90 Si harness and dash form the junkyard for 50 bucks took me about 3hrs to pull everything back to the tails. So Im hoping that everything lines up.. But for sure if you change the harness stay within 88-89 and 90-91 because i know that there were some changes in the wiring in those years........Good Luck To You
leroy12
Dec 17, 2015 06:15 AM
JDMlyfestyle
Oct 21, 2005 03:49 PM
Superhatch
Jul 10, 2002 04:37 AM
