anyone repaint there moldings black
I'm about to do mine, i think it looks way better. Any reference lines i should look out for. Only thing i've seen is from other pics. And what prep work did you guys do. I was going to use duplicolor trim paint. Hopefully it turns out ok.
Im going to polish the wheels, and hammer it.
Since your mouldings are painted already,I dont think that the duplicolor bumper paint will stick to your already painted mouldings. Just buy new ones.
moldings as in window moldings? i did mine last summer with duplicolor trim paint. came out pretty well... i left the windows down and opened the doors up then placed tape in the crack where the window goes. and i pressed it into the small crack above the molding between the molding and the paint. then i cleaned with alcohol and sprayed away. if you are talking about the mid door side moldings i just wasted a bunch of time.
ps... rex looks cleeeaaannn!!!
edit:
edit:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx »</TD></TR><TR><TD CLASS="quote">will do.
And i was reffering to crx's, cuz the bottom moldings on the bumpers look a little tricky.</TD></TR></TABLE>
I did the bottom part of my crx (also did the rear) , but mine were black to begin with, take a look...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. »</TD></TR><TR><TD CLASS="quote">Since your mouldings are painted already,I dont think that the duplicolor bumper paint will stick to your already painted mouldings. Just buy new ones.
dude to get the paint to stick just scuff the other paint and stuff with some scoth brite it will stick then. i think i am about to paint my moldings and stuff. they also have this stuff for ppl whose are already black called back to black from mothers and it is suppose to work really good.
use SEM bumper paint. The one called honda black...# 39293. Just scuff up the paint ont he moldings and bumper and it will stick fine. I used it on my car and it came out perfect. The duplicolor one is a little dark.
-James-
-James-
