need 89 crx si cluster wiring diagram
Old Jun 29, 2005 | 06:54 PM
LudeJdm's Avatar
Default need 89 crx si cluster wiring diagram
Old Jun 29, 2005 | 07:55 PM
HardSaltydogg's Avatar
Default Re: need 89 crx si cluster wiring diagram (envysionHATCH)
https://honda-tech.com/zero...age=1
Old Jun 29, 2005 | 08:03 PM
LudeJdm's Avatar
Default Re: need 89 crx si cluster wiring diagram (HardSaltydogg)
koo...need 88 civic hatchback dx wiring diagram
Old Jun 29, 2005 | 08:17 PM
for what reason?
I just did a crx conversion to my 88 dx, I probsbly could help
Old Jun 29, 2005 | 10:17 PM
LudeJdm's Avatar
yea can u help...i have an 88 hatchback dx...and im switching out the cluster...i bought a 89crx si cluster...thinking its juss plug n play....but when i installed it...the fuel n temp gauges dont work...and the hi-beam indicator doesnt lite up....i find out that it the cluster fits physically...but the internals are different meaning the wiring is different...now i need to re-pin the wires to match the crx cluster.....
Old Jun 30, 2005 | 07:14 PM
Easy, all the wires are color coded the same, it is just the positions in the clip. Cut and connect homie. Remember that there are some same colored wiring on both side, same side same colors. There is, I think a total of 3 wires that need to be crossed. Hope it helps, ask questions when needed
Old Jun 30, 2005 | 07:24 PM
LudeJdm's Avatar
i juss took a look at my wires and wrote down where the wires are...and used the crx diagram to figure out where to move them....yea i have a couple to move around....
Old Jul 1, 2005 | 07:09 PM
LudeJdm's Avatar
what year crx did you convert your hatchback???cuz depinned and repinned the wires according to the diagram and it still aint workn...
Old Jul 2, 2005 | 09:31 PM
I did a 91 crx auto into an 88 civic 5 speed. It all worked out for me except with the hazards and dimmer, Warnig Keep your og hazards and dimmers, I am still trying to figure out how to convert them
Old Jul 2, 2005 | 09:42 PM
LudeJdm's Avatar
do you have the 88 civic pin diagram or do you know the functions have each wire and color???and location??? if so that would help a lot...thanks
Old Jul 3, 2005 | 02:05 PM
LudeJdm's Avatar
need that diagram
Old Jul 3, 2005 | 05:42 PM
LudeJdm's Avatar
never mind solved problem....delete post....
SloB16crxMike
May 11, 2006 04:11 PM
Zatzy
10
Jul 8, 2005 07:55 AM
EF9Si-T
Feb 16, 2004 09:49 AM
maximedx
Jul 28, 2003 11:46 AM
