jdm b16 distributor question
i think my dizzy took a ****. could i throw on an obd-0 single cam dizzy just to see if the car will idle or would i need to use an obd-0 LS dizzy with one bolt holding it on?
-spenc
-spenc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunger »</TD></TR><TR><TD CLASS="quote">either will work, as long as you can get them to be in the right position.</TD></TR></TABLE>
OBD-0 B16 distributor = 90-91 LS distributor
Same guts, same internals, same cap & rotor, same everything. Just one different leg position on the side that clears the VTEC solenoid.
bhigh
Feb 13, 2009 07:01 PM
