how to wire and make a h23a external type distrubutor on to a 1990 accord with a jdm h22a?
Old Jun 29, 2005 | 03:13 PM
superturboprelude's Avatar
Default how to wire and make a h23a external type distrubutor on to a 1990 accord with a jdm h22a?
ok heres the scenario im puttin in a h22a jdm motor in a accord cb7 1990 and im using the same wiring harness off the accord. well the jdm h22a have a h23 external type distributor and i was wondering how can i wire it up to make the h23 distributor to work on the accord wiring harness which is a internal coil type distributor so how can i make the h23 distributor work thanks in advance
Old Jun 29, 2005 | 06:03 PM
Default Re: how to wire and make a h23a external type distrubutor on to a 1990 accord with a jdm h22a? (supe
bump
Old Jun 30, 2005 | 02:02 AM
help?
Old Jun 30, 2005 | 04:16 AM
mgags7's Avatar
first off, the jdm h22a comes with an internal coil distributor, so if you can get that one, use it....
to make an external coil work you would have to add wires and crap from the bottom of the coil up to the distributor, it will be a big pain...
my car i had to make an external coil wiring harness fit an internal coil distributor, and that wasn't that bad to do.....
step by step for you i dont know what to say, because i dont remember, but i know there is a solid yellow wire, a solid green wire, and the wire you have now, the black with yellow stripe wire, those three came out from the bottom of the external coil and went somewhere, i dont quite remember, but search for a diagram, you may be able to find one....
the easiest thing though would be to get the real jdm distibutor, that is internal coil....
Old Jun 30, 2005 | 10:46 AM
Honda Sport's Avatar
you sure the JDM h22a has an external coil? I swear it had an internal coil. if it does, you dont' have to change anything seeing that the accord has an internal coil also.
Racars
May 13, 2009 11:18 PM
superturboprelude
May 5, 2007 03:15 PM
superturboprelude
Jun 30, 2005 02:01 AM
ionic_slim
May 24, 2004 06:37 AM
93R33Lude
Jan 31, 2004 05:25 PM
