How do you determine the diameter of I/C piping?
Old Jun 29, 2005 | 03:03 PM
rhd's Avatar
rhd
Default How do you determine the diameter of I/C piping?
i'm in the process of putting together a turbo mustang. Nothing super fast, just a built 351w based engine with a big single on it.
my goal is modest at only 500-550whp on pump...and i doubt i ever really tune for race gas, unless i get really bored on weekend.
so i'm just trying to figure out what diameter of i/c pipe i'm going to run.....and i wasn't sure if there was some kind of calculation to go by, or if you base it off hp figures..or what...
any help would be appreciated
Old Jun 29, 2005 | 03:14 PM
AspectIndustries's Avatar
Default Re: How do you determine the diameter of I/C piping? (rhd)
Maybe the piping from turbo to intercooler, the same size as the outlet on turbo?
and from intercooler to TB... Run a pipe exactly the same size as the throttle body inlet?
Thats what I would at least do.
Old Jun 29, 2005 | 03:52 PM
BlueShadow's Avatar
posted in the FAQ:
https://honda-tech.com/zero...02591
From what I've read your piping size should be matched up to the amount of airflow your turbo setup is going to have. But usually for the compressor to intercooler inlet people run the same size pipe as the compressor outlet. Then from intercooler outlet to TB you can run either a 2.25" or 2.5" piping. I dont think it would be a good idea to match piping size with your TB, because if you have a large TB (2.75"+) then you might end up going with a piping diameter that is too big.
Ron Burgandy
Jul 21, 2014 11:58 AM
1990hondaHF
Aug 16, 2006 10:17 PM
killablaze
Dec 1, 2005 04:18 PM
JM Performance
Jan 1, 2004 08:02 AM
Screamer
Apr 9, 2003 11:07 AM
