humming noise somewhere from intake?
Old Jun 29, 2005 | 03:02 PM
AznBlueBoy's Avatar
Default humming noise somewhere from intake?
ok i think this is most liekly coming from the skunk2 intake manifold for the h22.
its a humming noise which keeps my revs up a little bit and it will eventually go away and usually the humming starts when i slow down or clutch in and im rolling to the red light or something...anybody know what this could be?
Old Jun 29, 2005 | 03:50 PM
PrettyLude's Avatar
clogged pcv valve?
Old Jun 29, 2005 | 04:13 PM
jdmcivicferio's Avatar
Default Re: humming noise somewhere from intake? (AznBlueBoy)
I blocked the passage, it is the top port on the throttle body to let air in on cold start, skunk2 did not drill the hole right
Old Jun 29, 2005 | 08:17 PM
AznBlueBoy's Avatar
Default Re: humming noise somewhere from intake? (jdmcivicferio)
what did you block it with?
and can you show me a pic please?
Old Jul 1, 2005 | 10:59 AM
AznBlueBoy's Avatar
ok this sound is definately coming from the air filter.....the closer i get the the filter...the louder it gets.....anybody know what it is?
Old Jul 1, 2005 | 12:04 PM
4LugR's Avatar
man, i have the same thing, it only does it every once and a while.. i dont kno what it is tho.. maybe the hose clamp is loose? and its making like a lil noise??
Old Jul 1, 2005 | 12:22 PM
AznBlueBoy's Avatar
Default Re: humming noise somewhere from intake? (AEMPrelude916)
do you have a skunk2 intake manifold too?
my CAI is a little crooked...could that be it?
the s2 IM makes it hard to put the CAI on....maybe it messes up the flow which creates the noise?
Old Jul 1, 2005 | 12:26 PM
AznBlueBoy's Avatar
oh yeah....even when i take off the intake and its not connected to the TB....it still makes the noise...hmmmm?
Old Jul 1, 2005 | 01:10 PM
4LugR's Avatar
hmmm, iono, i still have the stock IM on, and mine makes the noise too. i was thinkin it was my bypass valve, but i havent tried to take off my intake yet, and see if it makes the noise. ill have to do that
Old Jul 1, 2005 | 01:13 PM
AznBlueBoy's Avatar
hmmmm well i don't have a bypass valve...lol
Old Jul 1, 2005 | 01:15 PM
4LugR's Avatar
hahaha, then that cudnt be ur problem... that narrows it down a lil bit... imma try to take my intake off, and see if it still does it
Old Jul 2, 2005 | 08:33 PM
AznBlueBoy's Avatar
well i was reading the skunk2 intake manifold thread and it looks like someone else figured out what made the sound and it was because the iac wasnt connected to the right spot....so is the iac and iacv the same thing or 2 different things?
also where is this on the skunk2 manifold?
Old Jul 2, 2005 | 08:44 PM
JonGP4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy &raquo;</TD></TR><TR><TD CLASS="quote">well i was reading the skunk2 intake manifold thread and it looks like someone else figured out what made the sound and it was because the iac wasnt connected to the right spot....so is the iac and iacv the same thing or 2 different things?
also where is this on the skunk2 manifold?</TD></TR></TABLE>
IAC and IACV are the same thing, Idle Air Control Valve.. and that is your problem.. its eirther dirty, or you need a new one..
Old Jul 2, 2005 | 08:48 PM
AznBlueBoy's Avatar
Default Re: humming noise somewhere from intake? (JonGP4)
if its dirty, it would make the annoying humming noise? do you have a picture of what the iacv looks like?
crazy4carz
Aug 28, 2007 05:29 PM
lke2drvgsr
Apr 18, 2003 09:49 AM
97teg415
Sep 3, 2002 08:46 PM
tuco_ruiz
Jun 23, 2002 11:40 AM
SiKSiR
Mar 16, 2002 10:16 PM
