Suspension & Brakes Theory, alignment, spring rates....
Stock Springs with KYB AGX Shocks
Old Jun 29, 2005 | 02:42 PM
mntdewred's Avatar
Default Stock Springs with KYB AGX Shocks
I'm currently riding on a Ground Control setup with KYB Gas Shocks. I'm going back to Stock Springs for my own reasons.
What is everything I need to make the stock springs work in conjunction with these shocks? Am I going to need this kit for each shock?: http://www.partsamerica.com/Pr...set=A
Thanks!
Old Jun 29, 2005 | 06:30 PM
mntdewred's Avatar
Default Re: Stock Springs with KYB AGX Shocks (mntdewred)
ttt
Old Jun 30, 2005 | 05:42 AM
AutoXer's Avatar
http://www.slhondaparts.com/br...=true
Here's a pic of the hardware needed. You should have everything except for number 10, because the rubber that comes with the GCs replaces it.
Old Jun 30, 2005 | 09:24 PM
mntdewred's Avatar
Default Re: Stock Springs with KYB AGX Shocks (AutoXer)
On the stock springs, shouldnt the taller springs be in the front and the shorter springs in the back?
Old Jul 1, 2005 | 07:38 AM
simonsays's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntdewred &raquo;</TD></TR><TR><TD CLASS="quote">On the stock springs, shouldnt the taller springs be in the front and the shorter springs in the back?</TD></TR></TABLE>
The stock springs should look like this. Fronts are on the right, rears are on the left.
Notice that on the rear springs...the coils are spaced farther apart.
Old Jul 1, 2005 | 05:56 PM
mntdewred's Avatar
Default Re: Stock Springs with KYB AGX Shocks (simonweiss)
Great thanks, everything is on and looks good
lxaccord51oxl
Suspension & Brakes
Dec 11, 2006 10:49 AM
Chronicsinners
Dec 16, 2004 02:09 PM
integrx
Nov 18, 2003 07:18 AM
BlendedEJ8
17
Feb 11, 2003 09:03 AM
