I need parts for a right side drive 1995 honda prelude
Old Jun 29, 2005 | 02:00 PM
soulassassin138's Avatar
Default I need parts for a right side drive 1995 honda prelude
So I bought this right side drive 1995 honda prelude with an h22a1 engine. i didnt get it in the best of shape. certain things are wrong with it. i need to know if anyone knows of any shops in the in the world or any web sites where i could get parts for a car like this. for the most part i can just engineer things to work, but i would much rather have to correct parts for it. i tried the U.K. market, but they are telling me that some of thier parts may not work on the japanese model preludes. everyone else is pretty much out of ideas.
Old Jun 29, 2005 | 06:42 PM
onefastrx7turbo's Avatar
Default Re: I need parts for a right side drive 1995 honda prelude (soulassassin138)
what kind of parts?
Neil
Old Jun 30, 2005 | 02:55 AM
ryanstev's Avatar
Strong Honda in Auckland New Zealand has the largest used parts shop in the southern hemisphere, so maybe you could try them.
We get Japanese imports here, so they'll have what you need.
http://www.stronghonda.co.nz/
Old Jun 30, 2005 | 03:48 AM
Default Re: (ryanstev)
i need a master cylinder, brake booster, a/c lines, catalytic converter. these must be compatible with the h22a1. i need a price listing and part numbers if possible.
Old Jun 30, 2005 | 07:31 AM
VisPreludeVtec's Avatar
Default Re: (soulassassin138)
h22a1 is a american H22 so dont buy the JDM parts for it
Old Jun 30, 2005 | 08:49 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulassassin138 &raquo;</TD></TR><TR><TD CLASS="quote">i need a master cylinder, brake booster, a/c lines, catalytic converter. these must be compatible with the h22a1. i need a price listing and part numbers if possible.</TD></TR></TABLE>
Wouldn't these parts be the same, just on the other side of the engine bay?
Old Jun 30, 2005 | 08:57 AM
Default Re: (Sam1am26)
i dont need engine parts. i need part that are right side drive exclusive. i thought about making modifications to american part, but that may be more hassle then what it is worth
Old Jun 30, 2005 | 08:59 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulassassin138 &raquo;</TD></TR><TR><TD CLASS="quote">i thought about making modifications to american part, but that <U>may</U> be more hassle then what it is worth</TD></TR></TABLE>
So you don't even know for sure if they are different... why don't you try and do some more research on that...
Old Jun 30, 2005 | 09:01 AM
nope the outlet on the master cylinder are located on the other side. i would have to cut into my wheel well under the hood to make it work. that is not worth trying considering the bolts to the shocks are located right there. as for the a/c line all i really need it to have the lines extended to the left side of the car. the catalytic converter im not sure about. its shorter than the one that is on my other prelude, so i need to just find one that will fit.
Old Jun 30, 2005 | 09:55 AM
are you sure the lines are different on the brake master? Cuz I lived in Japan for 3 years. All the cars I had were the same as the US counterparts. The brakes and clutch M/C's were the same. The lines on the US one cross over the cylinder, whereas the Japanese one just comes out and down. You may be right, but they are propabably the same as here. The US cat's are different. Less stringent emissions in Japan, so the cat is shorter. just replace the exhaust from the manifold back with a US version. I doubt you will find a Japanese cat here. Welcome to the world of driving a RHD car in a LHD country. More hassle than its worth.
Neil
Old Jun 30, 2005 | 10:58 AM
im sure the parts are different. its obvious if you look at them. i wish it were that easy to modify.
Old Jun 30, 2005 | 11:20 AM
the parts should be the same because they mass produce them. the only different thing is the wiring harness i thought? Plus like I said before you have a h22a1 which is a USDM spec motor
Old Jul 19, 2005 | 05:10 PM
kathleen's Avatar
Is a '92 very different from a '95? Sorry for the ignorant question but my car was in an accident and I would like to sell the parts. Do any '92 parts work for you?
Old Jul 19, 2005 | 06:58 PM
Prelude SIR-T's Avatar
Default Re: I need parts for a right side drive 1995 honda prelude (kathleen)
92-96 shuld be the same thats the 4th gen, if you have a RHD 92 everything is the same except some interior modifications that they made after 94
Old Jul 19, 2005 | 07:36 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
i live in douglasville to where the hell did you find a place to sell you a right hand drive prelude? as far as knew there isnt any good **** around here
Glyran
Feb 8, 2016 01:58 AM
mikester1222
Jun 29, 2011 10:26 PM
93boostludeSi
Mar 12, 2007 12:39 PM
Behan
Apr 11, 2003 01:50 PM
