integra shocks/springs fit on 96+ civic?
They should, but the rear fork will be a lil wider on the LCA. You will have to run washers in the rear. But other than that they should bolt right up.
Yep, I had to put a washer on each side of the rear shock forks to take up the space. I didn't need the brake line bracket thingy on the front shock either. In my case I used a set of Bilstein HDs from a Integra on a '98 coupe.
tuby
Sep 12, 2006 01:10 PM
eg:R
Suspension & Brakes
Jan 13, 2006 07:37 AM
