valve cover questions
Old Jun 29, 2005 | 08:21 AM
fanta!'s Avatar
Default valve cover questions
when you take the valve cover off...
-do you need to put something on top of the head after its removed?
-do all heads have a valve cover gasket, can i re-use the gasket?
while polishing it, what do i need to cover with masking tape, oil cap holder, spark plug holes?
any other suggestions?
TIA
Old Jun 29, 2005 | 08:58 AM
B18ls*RAYON's Avatar
Default Re: valve cover questions (father)
I reused my gasket.
As long as you don't rip/tear it when taking off the cover, you should be okay. I don't know what you need to do as far as prep work.
Old Jun 29, 2005 | 03:18 PM
fanta!'s Avatar
Default Re: valve cover questions (B18ls)
Old Jun 29, 2005 | 03:28 PM
.:Swig:.'s Avatar
i just close the hood
Old Jun 29, 2005 | 03:31 PM
92 EH2's Avatar
Default Re: valve cover questions (00mofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00mofo &raquo;</TD></TR><TR><TD CLASS="quote">i just close the hood </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18ls &raquo;</TD></TR><TR><TD CLASS="quote">I reused my gasket.
Old Jun 29, 2005 | 03:32 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by father &raquo;</TD></TR><TR><TD CLASS="quote">
TIA</TD></TR></TABLE>
no need to mask anything.
Old Jun 29, 2005 | 03:37 PM
fanta!'s Avatar
Default Re: valve cover questions (B_CRUZ)
dont even need to mask the spark plug holes and oil cap holder when spraying air craft remover?
Old Jun 29, 2005 | 03:40 PM
B_CRUZ!'s Avatar
dont even need to mask the spark plug holes and oil cap holder when spraying air craft remover?</TD></TR></TABLE>
not if you remove the valve cover from the motor.
remove the old gaskets though. the aircraft paint remover will eat it.
Old Jun 29, 2005 | 03:48 PM
fanta!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_CRUZ &raquo;</TD></TR><TR><TD CLASS="quote">
remove the old gaskets though. the aircraft paint remover will eat it.</TD></TR></TABLE>
what other gasket besides the valve cover gasket, the lil gaskets in the spark plug holes? what else?
thanks everyone
Old Jun 29, 2005 | 03:52 PM
B_CRUZ!'s Avatar
there should be 8 grommets (rubber w/metal. its the one that the studs go through that hold the valve cover in place)
8 spark plug gaskets that are stuck on the under side of the valve cover when removed.
and the big valve cover gasket.
remove the misc 10mm bolts that hold the spark plug wire holders down too.
pimpdd101
Jun 14, 2007 05:49 PM
RGK500
Feb 15, 2007 08:23 PM
BDRphaseTWO
Aug 7, 2005 02:42 PM
fanta!
Jul 5, 2005 12:46 PM
civic91
Dec 31, 2003 07:44 AM
