95 accord lx headgasket replacement/timing belt question.
95 accord lx. did a head gasket replacement. i need help on how to keep/tighten the timing belt tensioner?
and if the pertains to me with removing the head/cam and adjusting the valves?:
"You will need to make sure the rear balancer shaft in the right position...theres is a 12mm bolt on the back of the engine behind the water pump that you must remove and insert a screw driver into to hold it in the right position"
Next GenRacing
Dec 11, 2005 10:52 AM
Integacivic
Dec 6, 2004 11:30 PM
Integacivic
Dec 2, 2004 03:44 PM
