FS: 96 Civic EX b18c5, Volk, Autopower, etc.
Thought I would post this up here in the Local section. Engine block has 3500 miles on it, the chassis has 151K but is extremely clean for year/miles. It only comes with the Volk wheels or if you have your own you can bring them and we can work something out. Click on the link in sig for more details. I'm not parting it out yet but I will take offers on the swap (everything listed through the clutch + the harness and mounts)!
$10,500
MODS
2000 b18c5 block
oversize jdm itr pistons
hastings piston rings
ACL bearings
ARP rod bolts
ARP head studs
2000 b16a2 head
milled 10 thou
skunk2 stage 1 cams
Rocket gen2 valvesprings/Ti retainers
Hondata IM gasket
JDM ITR header w/ heatshield and fastline performance skid plate
2.5" carsound cat
Thermal R&D b-pipe
Spoon N1 rear section
Password JDM CF intake
Blox IM
RC 270cc injectors
obd1 converted using P28
ACT Streetlite flywheel
Exedy organic clutch
H&R full coilovers stage 4
Eibach 17mm rear sway bar
factory 22mm front sway bar
Carbing rear lower tie bar
Cusco OS Front upper strut bar
Ingalls front camber a-arms
15x6.5" Volk TE-37 +39mm offset
Toyo T1S tires 75% tread
DC2 rear disc brakes
Brembo front rotors
Axxis ultimate pads on all corners
Manual steering rack
JDM CTR headlights
JDM SIR front lip
JDM CTR thin side moldings
99-00 rear tails
Spoon Replica mirrors
USDM ITR front seats
Sparco Rev drivers seat
Autopower race roll bar (bolt in)
Skunk2 Shifter and shift ****
Eclipse 5423 CD deck
$10,500
MODS
2000 b18c5 block
ACL bearings
ARP rod bolts
ARP head studs
2000 b16a2 head
milled 10 thou
skunk2 stage 1 cams
Hondata IM gasket
2.5" carsound cat
Thermal R&D b-pipe
Blox IM
RC 270cc injectors
Brembo front rotors
JDM CTR headlights
JDM SIR front lip
99-00 rear tails
