Question about wheels?
Old Jun 28, 2005 | 11:34 PM
Jacen's Avatar
Default Question about wheels?
Will 1990 Nissan 240 wheels fit on a prelude i found some technical specs. The reason I ask is because i'm looking into buying some wheels for my prelude, but the wheels are from a 240.
MODEL: PRELUDE SI
Year: 92-96
Size: 15 X 6
P.C.D. 4X114.3
Lug Size: 12mmX1.5
MM: 64.1
Offset: H
MODEL: 240SX
Year: 89-96
Size: 15 X 6
P.C.D. 4X114.3
Lug Size: 12mmX1.25
MM: 66.1
Offset: H
Offset H = High Positive or FWD (Front Wheel Drive) typically +45,40,35 offsets
Thanks in advance,
Jacen
Old Jun 29, 2005 | 05:03 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Question about wheels? (Jacen)
Looks like it should fit.
What is the width of the rims? Tire size?
Old Jun 29, 2005 | 12:08 PM
Jacen's Avatar
Default Re: Question about wheels? (Sticky Tires)
my stock ones right now are 195/60-15
the ones i'm looking at 205/60-15
Old Jun 29, 2005 | 02:12 PM
bad-monkey's Avatar
tires are too tall, and you'll want to find the exact offset for the wheel before you go ahead and buy some. the difference b/w +30 and +45 is huge in terms of looks and compatibility.
Old Jun 29, 2005 | 02:18 PM
Jacen's Avatar
Default Re: (bad-monkey)
what is the preludes stock offset?
Old Jun 29, 2005 | 02:43 PM
cfran55's Avatar
Default Re: (Jacen)
wow nice question i have both cars and wonder would wheels be like switchable lol
Old Jun 29, 2005 | 02:59 PM
Jacen's Avatar
Default Re: (CFran55)
Bump for the answer
Old Jun 29, 2005 | 03:00 PM
92SleeperH23's Avatar
If I remember a 4th gen Prelude's offset is +50....but I could (and prolly am) wrong
Anyways, I'm kind of in the same field, I want some wheels that I assume are intended for Nissans with a +35 offset for my Prelude, before I spend the money I'd like to make sure they fit (16x7 btw)
Old Jun 30, 2005 | 12:45 AM
Jacen's Avatar
bump for someone who has the answer.
Old Jun 30, 2005 | 04:14 AM
* B A N N E D *
If one offset is 35+ and the other is 45+, it will not fit. As bad-monkey stated, you need to find the correct/closest offset.
Old Jun 30, 2005 | 03:49 PM
Jacen's Avatar
but what is the 4th gens prelude stock offset?
Old Jun 30, 2005 | 05:51 PM
my9thtry's Avatar
if memory serves me correctly its 45. hope it helps but wouldnt try running 240 rims they use like 20 somehting offset
Old Jun 30, 2005 | 06:06 PM
cfran55's Avatar
Default Re: Question about wheels? (my9thtry)
dang so 240 wheels wont fit
Old Jun 30, 2005 | 06:49 PM
Cashis Lee's Avatar
Default Re: Question about wheels? (CFran55)
They will fit and work, but how well they work is a different question
Old Jul 1, 2005 | 09:58 AM
tge39's Avatar
45et sounds right to me about that offset for the 92-96 prelude. Pretty sure that the 240 wheels are going to be to low of n offset for the lude. Usually the rear wheek drive applications dont fit the fwd applications.
superiorx120
Nov 28, 2010 10:00 AM
STYLiNxCHiQ_DA9
Mar 31, 2010 09:59 PM
XzzRzzX
Oct 2, 2006 11:51 AM
prelude760
Nov 14, 2005 03:35 PM
