Made a bunch of room under the hood
Old Jun 28, 2005 | 10:33 PM
cvcrcer's Avatar
Default Made a bunch of room under the hood
I removed the entire AC system and removed the cooling fan and came up with this...
I put a slimline electric fan in front of the radiator as a pusher fan.
a closer look...
I now have a bunch of room under the hood and the car is running great.
Old Jun 28, 2005 | 10:43 PM
Sequoyah's Avatar
Default Re: Made a bunch of room under the hood (cvcrcer)
Looks great! Let me have your A/C now.
Old Jun 28, 2005 | 10:47 PM
cvcrcer's Avatar
Default Re: Made a bunch of room under the hood (Sequoyah)
the hoses and condenser are damaged and no good. You can have the fans, evaporator, and compressor. I make no gaurentee that it works though. It hasn't worked since i bought the car.
Old Jun 28, 2005 | 10:55 PM
julio_bOostamante's Avatar
I'm a Jackass
good job on making some room, now go stuff a turbo in all that free scpace
Old Jun 28, 2005 | 10:59 PM
cvcrcer's Avatar
Default Re: Made a bunch of room under the hood (julio_bOostamante)
yeah that is what I am thinking about. I'm not going to do it to this engine though. It's too old and just a DPI 1.5 I'm either going to get another car to be my daily driver or a shell to build.
Old Jun 28, 2005 | 11:00 PM
CRseXy's Avatar
hmm I wonder if I can put the fans infront as well, but keep my AC.
Old Jun 28, 2005 | 11:04 PM
cvcrcer's Avatar
Default Re: Made a bunch of room under the hood (pogiTSI)
I don't think it's possible. It took most of the space that the condenser was in to mount the new fan.
Old Jun 29, 2005 | 12:00 AM
teler86's Avatar
I have a b16 swap so my A/C is already removed how would i move my fans up front?
Old Jun 29, 2005 | 12:19 AM
SiMateoAko's Avatar
that looks hawt. I'm jealous. I would love to have that space available.
Check that lower radiator hose... it looks spooky.
Old Jun 29, 2005 | 12:50 AM
cvcrcer's Avatar
Default Re: Made a bunch of room under the hood (SiMateoAko)
I guess I can write this up as a DIY thing.
Ok head over to pep boys, O'reilly's, Autozone etc. and get a slim electric fan like this
After you have removed the AC condenser you should have room to mount the fan in front of the radiator. The wiring and mounting instructions are included with the fan.
Take the front bumper off (you're on your own there, mine's easy. Yours may not be) install the fan and cut the connector off of the OEM fan unit.
Remove the OEM fan assembly. Should just be 2 scews up top and a tab or two on the bottom.
Wire the fan up (NOTE: Don't make it a permanent connection) My fan came with a Blue and a black wire fron the motor. The OEM connector also has a blue and a black wire. I had to connect the Black to blue and vise versa to get the fan spinning in the proper direction. Make sure it is pushing air into the engine bay! To test this just let the engine idle until it gets hot. The fan will kick on.
Once you are sure it is pushing air through you are finished. Just put the bumper back and secure the wiring and you are all set.
I'll get some pics of the fan install posted later.
Old Jun 29, 2005 | 12:51 AM
cvcrcer's Avatar
as far as the radiator hose goes it's just rust on the hose clamp. I'm plannign to get some new ones soon.
Old Jun 29, 2005 | 03:27 AM
88 rex's Avatar
Default Re: (cvcrcer)
How much for the fan?
I wonder if this is more effective since you're pulling in cooler outside air instead of pushing out hot motor air?
Hmmmmm
Old Jun 29, 2005 | 05:23 AM
teler86's Avatar
Default Re: (88 rex)
how much is the fan?
Old Jun 29, 2005 | 05:35 AM
CRseXy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">How much for the fan?
Hmmmmm</TD></TR></TABLE>
Technicly is pushing air, not pulling. Stock its pulling. But IMO pushing air Thru the rad is more efficent.
Old Jun 29, 2005 | 10:48 AM
cvcrcer's Avatar
Default Re: (pogiTSI)
I had the fan laying around from an old RX7 project I was doing a while back. I want to say I paid about $30 for it. I know it's less than $50.
Old Jun 29, 2005 | 11:18 AM
Ass$nyper's Avatar
Pirate General...YARRRR
you'll miss A/C i did but cool
Old Jun 29, 2005 | 11:19 AM
cvcrcer's Avatar
Default Re: (Ace$nyper)
The AC hadn't working int he year I had the car. I wasn't all about dumping money into fixing it so I doubt I'll be missing anything except about 45lbs from the car.
Old Jun 29, 2005 | 01:56 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI &raquo;</TD></TR><TR><TD CLASS="quote">Technicly is pushing air, not pulling. Stock its pulling. But IMO pushing air Thru the rad is more efficent.</TD></TR></TABLE>
Old Jun 29, 2005 | 02:26 PM
No-Gi's Avatar
How big is it 10 inches?
Old Jun 29, 2005 | 03:43 PM
jade butterfly's Avatar
i don't think i could part with A/C...
but it looks good.. great that there's extra room and the car runs great though
Old Jun 29, 2005 | 04:54 PM
Rob.'s Avatar
Default Re: Made a bunch of room under the hood (jade butterfly)
I dont think it's good to have the fan in front of the radiator...
The fan should be inside the engine bay to blow hot air out if the engine bay...
makes sense no ?
I just left my stock fan in there.
Old Jun 29, 2005 | 05:08 PM
88 rex's Avatar
Default Re: Made a bunch of room under the hood (Rob.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">I dont think it's good to have the fan in front of the radiator...
makes sense no ?
I just left my stock fan in there. </TD></TR></TABLE>
Old Jun 29, 2005 | 06:11 PM
solfly's Avatar
fans are more efficient pulling through the radiator from the engine side, thats why they are there OEM
Old Jun 29, 2005 | 06:53 PM
CRseXy's Avatar
makes sense no ?
nah, If you read the thread. Stock, the fans are PULLING air THRU the rad, meaning its pulling air from the front, thru the rad, INTO the engine bay. its still going to blow hot air into the engine bay.
Old Jun 29, 2005 | 06:58 PM
Rob.'s Avatar
I still think the honda engineers know best ...no ?
