installing a new Rad, got some questions
Old Jun 28, 2005 | 10:05 PM
sniperslayer's Avatar
Default installing a new Rad, got some questions
k well my rad's been leakin out the front for a while, and right when it started i poured that copper ball "stop leak" **** into the rad, even after like 4 months of topping it off every 2nd day and **** there is still alot of that crap in there
espeically in the resoivoir it's like a ******* paste of that ****
anyways, i'm asuming since it's in the rad it's been going through the engine, so do u guys think i should do some sort of engine flush before i install the new Rad?
if so plz recomend products available in canada
Old Jun 28, 2005 | 11:00 PM
dohcdelsol's Avatar
Default Re: installing a new Rad, got some questions (sniperslayer)
I know my shop does coolent flushes but it cost a **** load.
When i instuled my new stock rad, i did a coolent flush after i did the rad. If you want to be really sure, do a coolent flush now, put the new rad in, then do another but i dont think you really need to go that far.
Old Jun 28, 2005 | 11:17 PM
Dancing is Forbidden's Avatar
Default Re: installing a new Rad, got some questions (dohcdelsol)
but you def need a coolant flush. I would never put that garbage near my radiator.
Old Jun 28, 2005 | 11:37 PM
JCritt's Avatar
Default Re: installing a new Rad, got some questions (ih8jdm)
i never knew that stop leak stuff could be harmful to your engine...
Old Jun 29, 2005 | 09:10 AM
Default Re: installing a new Rad, got some questions (khaa)
i had no money at the time so was kinda forced to use it
anyways TTT
how much is a fluid flush and where can i get one done?
Old Jun 29, 2005 | 09:12 AM
Kyles ej1's Avatar
y not flush it yourself? cant u just drain it flush it with a hose or whatever they use and put it back in instead of spending money to get it done?
Old Jun 29, 2005 | 08:12 PM
Default Re: installing a new Rad, got some questions (93ejay1)
ahh does anyone have more detailed instructions on flushing a rad yourself? i need to flush the **** within the engine as well, so i would guess drain out all the crap in there now, fill with water, run the engine, drain and repeat?
Old Jun 29, 2005 | 09:23 PM
CarbonCreations's Avatar
make a syphon.. disconnect rubber hose to drain out the rad fluid. put a hose in the rad resevoir. turn on car. leave running until water comes out of rad hose. turn off hose. wait til no water runs out of motor. huzzah.
and dont run the degunk stuff through your motor if you're above 150k.. all that carbon coke is probably HELPING to keep your motor together.
Old Jun 29, 2005 | 09:43 PM
Default Re: installing a new Rad, got some questions (CarbonCreations)
thanks carbon!
ttt for any more ideas
Old Jun 30, 2005 | 11:14 AM
ttt
PatrickGSR94
Nov 20, 2010 04:31 AM
cc11386
12
Oct 25, 2005 03:22 PM
GroundZer0 336
Nov 22, 2003 08:09 PM
reekoh
Sep 12, 2002 06:57 PM
