Video of my 13.52 Run @ Sacramento Raceway
Old Jun 28, 2005 | 09:17 PM
xludexgenx5's Avatar
Default Video of my 13.52 Run @ Sacramento Raceway
http://www.blacktrax.net/CMI6-26-05.html
Sorry dont know how to save the video from the website, this run was on 100octance, 22 x 15 slicks, ALL Motor, Full Interior.... hope ya like..
Old Jun 28, 2005 | 11:04 PM
MySelfAffliction's Avatar
Default Re: Video of my 13.52 Run @ Sacramento Raceway (xludexgenx5)
What are your mods if you don't mind telling?
Old Jun 29, 2005 | 12:05 AM
Default Re: Video of my 13.52 Run @ Sacramento Raceway (MySelfAffliction)
Head:
Blacktrax Stage 2 ported and polished head
Blacktrax Ported Intake Manifold
Blacktrax Deburred Combustion Chambers
Blacktrax Balanced and Polished Rocker Arms
Blacktrax/SuperTech High Compression Flat Valves
Blacktrax Deburred Head
Blacktrax Modified Valve Cover
Blacktrax/SuperTech Titanium Valve Springs & Retainers
RS Akimoto Velocity Stack
Crower Stage 3 All Motor Cams
Hondata Heat Resistant Intake Manifold Gasket
STR 68mm Billet Throttle Body w/Match Ported Manifold
AEM Fuel Rail
AEM Fuel Regulator
AEM Fuel Filter
AEM Tru Power Pulleys
AEM Cold Air Intake
OBD 1 Stock h22 Injectors
Earls Stainless Steel Fuel Line
STR Cam Gears
NGK Spark Plugs
NGK Wires
Block:
Stock JDM h22
Moroso Aluminum Racing Oil Pan w/ Baffle & Trap Door
Moroso Oil Pick up
Mr.Gasket Head Gasket
ARP Head Studs
Misc:
Energy Motor Mount Inserts
Removed AC
Removed Cruise Control
(edited)
Transmission:
JDM h22 LSD transmission
ACT 12lb Flywheel
Blacktrax/Superior Custom 4 puck Copper/Kevlar Clutch
Royal Purple SyncroMesh
Modified by xludexgenx5 at 2:23 AM 6/29/2005
Modified by xludexgenx5 at 2:01 PM 6/29/2005
Modified by xludexgenx5 at 10:55 AM 7/1/2005
Old Jun 29, 2005 | 01:22 AM
97lude's Avatar
nice run
Old Jun 29, 2005 | 08:18 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xludexgenx5 &raquo;</TD></TR><TR><TD CLASS="quote">
Transmission:
JDM h23/Vtec LSD transmission
Are you sure? The JDM H23A only cam with an automatic tranny... What is your tranny code?
Old Jun 29, 2005 | 09:21 AM
Default Re: Video of my 13.52 Run @ Sacramento Raceway (Sam1am26)
not sure, have to check it later when I get a chance, the transmission came off of a h23/Vtec motor, so maybe the engine supplier switched the transmissions then, I know its LSD for sure though, I'll check later and post it...
Old Jun 29, 2005 | 09:41 AM
machine4321's Avatar
man nice number's
love seeing a street car other than a civic in the 13's/.
what numbers you putting down
what header is that ..
and whats the weight on the car
this give my accord some hope
thanks
Old Jun 29, 2005 | 09:55 AM
Default Re: (machine4321)
on a Dyna Pack 3000 I put down 201.2 HP & 144.6 TQ
Prospeed 4-1 Header... (not the best header to have lost alot of midrange)
Last time I weighed it, it was 2830lbs
running the car with full interior, only real major weight reduction was th CF hood..try to scan the timeslips later to post up.. people still think I'm on the bottle, cant believe that a chassis like a prelude or accord can run 13's N/A..
Old Jun 29, 2005 | 10:12 AM
i bet theres a lot of haters ...my goal is a 13.5 with back seats
Old Jun 29, 2005 | 10:47 AM
. o 69 o .'s Avatar
nice pass
Old Jun 29, 2005 | 12:39 PM
musclefella's Avatar
Default Re: (B16B)
Nice pass the car sounds great.
Old Jun 29, 2005 | 12:42 PM
Default Re: (musclefella)
heres a couple of pics of my motor & the 13.6 run...
Old Jun 29, 2005 | 12:54 PM
Sam1am26's Avatar
Removed AC
Relocated Battery
Removed PS
Doesn't look like that in the pics...
Old Jun 29, 2005 | 01:01 PM
whoops forgot to update, P/S is on and bat got relocated back to the front, it was too much trouble to have in the trunk...sorry thanks for pointing it out...
Old Jun 29, 2005 | 01:15 PM
edulerp97's Avatar
That is impressive.....Good work. WHat was your 60ft? The video didn't come out for me. Nice numbers....I think for the work you done your numbers should be higher......Anyways nice time for the lude.....
Old Jun 29, 2005 | 01:21 PM
Sam1am26's Avatar
Modified by Sam1am26 at 7:49 PM 7/1/2005
Old Jun 29, 2005 | 01:44 PM
4bidden's Avatar
You were running brackets, were ahead by a LOT at the finish line, and you didnt let off? Come on now!!!
Old Jun 29, 2005 | 01:50 PM
98vtec's Avatar
moderator emeritus
Default Re: Video of my 13.52 Run @ Sacramento Raceway (edulerp97)
dynopacks read alot lower than roller dyno's. I would guess he is in the 215whp area on a roller.
Old Jun 29, 2005 | 03:24 PM
edulerp97's Avatar
Default Re: Video of my 13.52 Run @ Sacramento Raceway (98vtec)
I hope so because I was like damn that's kinda low for his mods that he has. Excellent run though.
Old Jun 29, 2005 | 07:17 PM
where do you see A/C? the lines normally run right by the header theres nothing there..
Old Jun 29, 2005 | 07:24 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xludexgenx5 &raquo;</TD></TR><TR><TD CLASS="quote">where do you see A/C? the lines normally run right by the header theres nothing there..</TD></TR></TABLE>
i no see em
Old Jun 29, 2005 | 07:25 PM
SiB16A's Avatar
good run man
Old Jun 29, 2005 | 07:43 PM
The Birdman's Avatar
good run I hope to be runnin some 13's in my 4th gen with full interior.
Old Jul 1, 2005 | 09:55 AM
Default Re: Video of my 13.52 Run @ Sacramento Raceway (jd3jdm)
the transmission is just a regular h22 transmission but with LSD.... the shotp the motor came from just swapped it out... just checked it out..
Old Jul 1, 2005 | 02:25 PM
ALTERED4's Avatar
congratulations... not too many preludes around running 13's all motor... actually, you're the first 5th gen i've heard of...
drop some weight... run faster...
my prelude weighs around 2700 with me in it, and i'm only putting down 184 whp...
