Does anyone have a Design made up for Traction Bars?
Old Jun 28, 2005 | 08:03 PM
WadeH's Avatar
Default Does anyone have a Design made up for Traction Bars?
I was wondering in anyone had a full design specs and all for a set of traction bars.
Old Jun 29, 2005 | 07:00 AM
blackcivic44's Avatar
Default Re: Does anyone have a Design made up for Traction Bars? (boostedb18a)
I remember Louie from LCON saying that he'd help people out who were interested in making their own cause he didn't want people driving around with incorrect geometry, i'd suggest contacting him
Old Jun 29, 2005 | 07:59 PM
WadeH's Avatar
Default Re: Does anyone have a Design made up for Traction Bars? (blackcivic44)
Do you no a way i could contact him? Thanks alot for pointing me in the right direction!
Old Jun 30, 2005 | 04:35 AM
https://honda-tech.com/zero...72905
Old Jun 30, 2005 | 08:46 AM
WadeH's Avatar
Thanks for the help!!!
Wade
Old Jun 30, 2005 | 12:58 PM
L-CON1's Avatar
i will sell everything you need to make your own kit. pm me!
Old Jan 30, 2007 | 05:54 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Re: Does anyone have a Design made up for Traction Bars? (L-CON1)
anyone have specs on like how bi the radius rods should be, how far apart they should be etc
I need info like that if it matters
Old Feb 1, 2007 | 02:38 AM
PINKS's Avatar
Default Re: Does anyone have a Design made up for Traction Bars? (WadeH)
Old Feb 1, 2007 | 04:44 PM
REEMB18C1's Avatar
hows it goin im very instrested in purchasing all parts necessary for making a goo set of traction bars i have a 92-95 civic
Old Feb 1, 2007 | 05:01 PM
PINKS's Avatar
Default Re: Does anyone have a Design made up for Traction Bars? (REEMB18C1)
Why do most companies stay away from only using 2 heim joints on the front and a solid piece with 2 holes drilled to go where your stock radius rods bolt up?
I want to make my own bars and would like to save as muhc as possible, if it doesnt hurt anything
Old Feb 1, 2007 | 05:20 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-CON1 &raquo;</TD></TR><TR><TD CLASS="quote">i will sell everything you need to make your own kit. pm me!</TD></TR></TABLE>
Old Feb 2, 2007 | 03:24 PM
PINKS's Avatar
Default Re: Does anyone have a Design made up for Traction Bars? (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">Why do most companies stay away from only using 2 heim joints on the front and a solid piece with 2 holes drilled to go where your stock radius rods bolt up?
Old Feb 13, 2007 | 03:31 PM
PINKS's Avatar
Ive started fabbing this bar in my spare time, got me heim joints on order and they will be here anyday
One thing Ive come to a stop on is my radius rod bars. I went with a solid mount at the LCA, and instead of making something to bolt to the LCA, I simply cut off the end of the stock radius rods, stuck them into my 5/8" ID bar and welded it on.
Now with both bolts in the LCA, it holds my radius rods (at the front of the car) about 3 1/2" above my new crossbar since I went quite low with it, maybe 2" lower than stock.
I was hoping to simply heat up and bend the stock portion of the radius rod I cut off, bend them to the correct angle to meet up with the crossbar.
Was curious if that would cause any problems?
Old Feb 24, 2007 | 01:50 PM
Mikizzle's Avatar
Would like to know also
Red_ED8
Sep 26, 2006 10:36 AM
Marlon88
Apr 21, 2005 06:46 PM
Marlon88
Apr 21, 2005 05:02 PM
s o h c
Oct 18, 2003 06:07 AM
RTW DC2R
Jun 14, 2003 05:43 PM
