1990 Accord Rev Limiter problem?
Old Jun 28, 2005 | 07:12 PM
jaythor's Avatar
Default 1990 Accord Rev Limiter problem?
I'm having a problem that seems like the rev limiter (if there is one on the car) engages at ~3500 rpm. Any ideas? Thanks.
Old Jun 28, 2005 | 07:36 PM
NAiL05's Avatar
Default Re: 1990 Accord Rev Limiter problem? (jaythor)
I dunno if theres a rev limiter on the 1990. But have you checked your throttle cables. Maybe TPS? I got a rev limiter on my 92 but it aint till 7k rpm on stock motor.
Old Jun 29, 2005 | 06:56 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaythor &raquo;</TD></TR><TR><TD CLASS="quote">I'm having a problem that seems like the rev limiter (if there is one on the car) engages at ~3500 rpm. Any ideas? Thanks.</TD></TR></TABLE>
Is the check engine light on? Does it have any trouble codes stored?
Old Jul 3, 2005 | 08:21 PM
jaythor's Avatar
Any recommendations on where to get fault codes diagnosed? I'm trying not to spend a lot of money troubleshooting this problem since the car is getting to the point where it is a debate on whether is it worth fixing or not. Thanks for the help.
Old Jul 3, 2005 | 09:39 PM
momstaxi's Avatar
you can do it yourself, there is a two wire connector under the dash, stick a piece of wire in both ends and it will flash the code(s)on the dash via cel light.... then look on the internet or in your book and find the code and see the problem...
or autozone will do it for free...
Old Jul 8, 2005 | 02:51 PM
jaythor's Avatar
Default Re: 1990 Accord Rev Limiter problem? (momstaxi)
The S light flashed so I'm assuming that is a TCM code. It gave code 14. From my research that should be a "short or open in FAS (BRN/WHT) wire between the D16 terminal and ECM" or "Trouble in ECM", anyone confirm this? Thanks.
Old Jul 8, 2005 | 04:18 PM
90cord90's Avatar
could take a look here:
http://home.earthlink.net/~mic...2.PDF
http://home.earthlink.net/~mic...1.PDF
CPUv2
Apr 17, 2009 11:59 AM
Freeman1017
Aug 26, 2008 06:38 AM
halfcard
May 4, 2007 07:02 PM
eknine
Jul 18, 2003 08:06 PM
