Suspension & Brakes Theory, alignment, spring rates....
RWD
Old Jun 28, 2005 | 03:45 PM
.Ryan's Avatar
Don't Trust Anyone
Default RWD
On a RWD vehicle, does upgrading the rear sway bar size have the same effects as a fwd vehicle? Should I just do the rear first, and think about the front later?
Old Jun 28, 2005 | 04:59 PM
Targa250R's Avatar
be professional
Default Re: RWD (SHAGGY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHAGGY &raquo;</TD></TR><TR><TD CLASS="quote">On a RWD vehicle, does upgrading the rear sway bar size have the same effects as a fwd vehicle?</TD></TR></TABLE>
Yes. Increasing roll stiffness at the rear end of the car will decrease grip at that end, resulting in less understeer/more oversteer. Keep in mind that using a larger sway bar at the driven end of the car will make it more difficult to put the power down with an open differential due to the weight transfer from the inside wheel to the ouside wheel.
Old Jun 28, 2005 | 06:11 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: RWD (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Yes. Increasing roll stiffness at the rear end of the car will decrease grip at that end, resulting in less understeer/more oversteer. Keep in mind that using a larger sway bar at the driven end of the car will make it more difficult to put the power down with an open differential due to the weight transfer from the inside wheel to the ouside wheel.</TD></TR></TABLE>
Sounds worthless then. What about with LSD?
Midori Green
Jun 21, 2008 01:04 AM
EKBOOSTDREAMS
Aug 19, 2007 02:26 PM
Team RS2
May 5, 2007 01:24 PM
jtl
Mar 31, 2004 06:34 PM
No-Gi
Jun 22, 2003 11:38 PM
