How do i change my stock audio?
I can't seem to figure out how to change my head unit so i can install a cd player.
As goes for the front speakers, I can't get the door panel off( I manage to get the screw in the pocket holder, screw at the left hand corner of the door and pull the bottom so they pluck out, but around the door lock doesnt seem to come out. Help!
assumming yo uhave a 92-93 civic..
for the head-unit, loosen all the screws that hold the center console/ash tray. put it aside and you'll see the metal frame along with the stock head unit. now there might be (usually) 2 phillip head screw in the very back of the unit that is bolted to the metal frame. loosen that out and the head unit should be able to come out..
now for the door panel;
-there shoud be a plastic screw on the uppe left corner of the panel.
-loosen the screw that hold the plasitic trim where you would rest you arm.
-on ths side of the panel, right by where the door hinge would be, there is a screw that hold it o nthe side.
-also take out the trimming that surround the door lever where you could open the door.
-then all you have to do is pull the panel off the door starting from the bottom on the corner and work you way around.
-after the panel pop all out, lift if off of the door by sliding it upward.
hope that help or cover it.
hoboneedshemp
Audio / Security / Video
Mar 17, 2006 03:06 PM
