Suspension & Brakes Theory, alignment, spring rates....
H&R OEM SPRINGS....???
Old Jun 28, 2005 | 11:40 AM
joshcivic00's Avatar
Default H&R OEM SPRINGS....???
I have been having a problem with my susp. setup for about 6 months it happens at the front left tire and it makes a knocking sound when i hit a sharp bump!(I have a 00 civic with ground controls on kyb gr-2's with 215/35/18's) I was wondering if i could fix this,because i think it is a spring/clearance issue, by getting some H&R OEM springs that only drop .75inch to raise it up some! My front tires are basically touching the fenders and i cannot get them to go any higher, will this help??
p.s. b4 the lowering i had 1.5-2 inch clearance in wheel well!
Old Jun 28, 2005 | 12:04 PM
AutoXer's Avatar
Default Re: H&R OEM SPRINGS....??? (joshcivic00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshcivic00 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 00 civic with ground controls on kyb gr-2's with 215/35/18's) </TD></TR></TABLE>
Why can't you raise the car up? Have you looked under there to see what might be going on to cause the noise? How low are you dropped?
AznBlueBoy
Suspension & Brakes
Jul 19, 2011 10:14 AM
variable
Oct 20, 2009 08:14 AM
EG6 Poe
Suspension & Brakes
Aug 23, 2008 10:08 AM
M@
Nov 18, 2007 01:41 PM
integra95gsr
Mar 21, 2006 09:08 PM
