rear disc problem
Old Jun 28, 2005 | 09:56 AM
spcrxracer's Avatar
Default rear disc problem
1991 CRX Si
okay, so something on the left-rear side of my car is bent, and im changing out the whole suspension on that side, and i was just wondering if i changed it to DA integra, would i have to change both sides or would i be okay just changing out the left side only?
Old Jun 28, 2005 | 09:58 AM
dr_latino999's Avatar
Default Re: rear disc problem (spcrxracer)
The DA Trailing arm adds about a 1/4" - 1/2" to the wheel base of the car (per side), so if you just add one it may look a little funny. On my sedan with DA trailing arms the rear has about an inch difference then the front with a perfect alignment.
Old Jun 28, 2005 | 10:03 AM
spcrxracer's Avatar
Default Re: rear disc problem (dr_latino999)
OKay, next question, are CRX Si and CRX DX trailing arms the same length??
Old Jun 28, 2005 | 10:04 AM
Yes
Old Jun 28, 2005 | 10:06 AM
spcrxracer's Avatar
THANK YOU DR LATINO!!!!
Old Jun 28, 2005 | 10:17 AM
Anytime
Old Jun 28, 2005 | 03:03 PM
spcrxracer's Avatar
okay, now my question, is can i take apart the rear disc & rear drums, and swap trailing arms and put it all back together?
Old Jun 28, 2005 | 03:26 PM
Tyson's Avatar
no, you cant interchange the disc brake stuff and put it on a drum brake trailing arm or vice versa.
so your question and answer to the DX and Si trailing arms being the same length does not help you in this case.
you really do need to find 90-91 Si trailing arms. which are kinda rare.
Old Jun 28, 2005 | 04:04 PM
Default Re: rear disc problem (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">no, you cant interchange the disc brake stuff and put it on a drum brake trailing arm or vice versa.
you really do need to find 90-91 Si trailing arms. which are kinda rare.</TD></TR></TABLE> Wronnggggggggg, I did it using spare sets of trailing arms to prove you could. All you have to do is remove the hubs (Torx Bolts in the rear) and switch.
Old Jun 28, 2005 | 04:11 PM
Tyson's Avatar
really? hmm... got some pics?
Old Jun 28, 2005 | 05:40 PM
No I don't have pictures but since my car is not operational at this current time I will be glad to try and grab pictures of the rear of the trailing arm. The difference is everything attached to the arm, no more.
Old Jun 29, 2005 | 10:02 AM
Tyson's Avatar
well youre right. sorry about saying the wrong info. i was misled by other comments from someone i trust, but i had just misheard what was said before.
Nottjbarlow
Feb 13, 2012 09:03 AM
jacksonww
Oct 5, 2010 05:09 AM
wickedEFguy
Apr 22, 2010 12:19 PM
Mr_CRX
32
Dec 17, 2004 08:29 AM
