knocking sound!! Need HELP BAD!
Ok I have been having problems with the front left part of my suspension!!!Every time i go over a big sharp bump I hear a knock sound coming from this area!! I have kyb gr-2's with ground control coilovers on my 00 civic with 18's!!! I tried to replace my front left shock,when i did The exact same thing continues to happen! can anybody help me or have any ideas because i can not figure out the problem and i am really getting sick of it!!! can anybody help??? and the coilover is raised all the way(the front right and left is alot lower then rear and i dont knw why)front left is the only problem!
Something is loose or simply put together wrong. First thing to go is pull the wheel off and tighten everything. Knocks and clunks come from parts moving and then impacting other things. It could be coming from poorly set coil-overs, loose arms, bottoming parts, etc. There are too many options to list so the answer is to get in there with wrenches and tighten things up and look for any unwanted opportunity for motion.
I had a similar situation coming from my front left tire. I don't know if its the same thing with you, but after a while, I checked underneath the suspension and noticed that a screw was missing from the LCA nut that screws it together. Apparently, the shop that fixed my wheel bearing forgot to put the metal rod thingie through the nut, which caused the screw to slowly slip down and fall off.
undertheradar
Oct 21, 2003 10:56 PM
JDM-FREAK
Sep 15, 2002 10:11 AM
