Prelude Master Cylinder Upgrade !
Old Jun 28, 2005 | 07:33 AM
Rob.'s Avatar
Default Prelude Master Cylinder Upgrade !
Want better braking ? Do this !!! Crx Si (7/8) or (13/16) MC to prelude 15/16 MC
SLIGHT BENDING OF 1 LINE REQUIRED..
edited: I bought the MC Today... Does it work with the stock Si Brake booster ? or do I need to change the BB as well ? I have searched but cant find an answer...
http://thezam.org/kam/preludemc.html
Modified by Rob. at 7:36 PM 6/29/2005
Old Jun 28, 2005 | 08:45 AM
speedracer228's Avatar
Default Re: Prelude Master Cylinder Upgrade ! (Rob.)
what did you use to bend the line so that you didnt crease it at all?
and dont you need the Prelude Brake booster to get the full effect from your larger MC?
(i have the prelude mc and bb sitting in my garage debating to sell or put on my ef)
Old Jun 28, 2005 | 08:49 AM
Rob.'s Avatar
Default Re: Prelude Master Cylinder Upgrade ! (speedracer228)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracer228 &raquo;</TD></TR><TR><TD CLASS="quote">what did you use to bend the line so that you didnt crease it at all?
(i have the prelude mc and bb sitting in my garage debating to sell or put on my ef)</TD></TR></TABLE>
I havent installed it.. I am looking to get a new MC for my crx, cuz I think mine is shot. On the side of my crx MC it says 7/8..is that right ?
I guess you need some forearm muscle to bend the line, or a heat torch.
You dont need the Prelude booster... Remember the 90-91 4 door ex is a direct bolt on and it uses the same 15/16 MC the prelude has... the only difference is that with the prelude MC, you need to bend 1 of the lines..
Old Jun 28, 2005 | 08:55 AM
EL Vap133's Avatar
I went with the easier 90-93 Integra MC/BB and my car stops on a dime!
Old Jun 28, 2005 | 08:57 AM
Rob.'s Avatar
Default Re: Prelude Master Cylinder Upgrade ! (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I went with the easier 90-93 Integra MC/BB and my car stops on a dime! </TD></TR></TABLE>
easier ? how so ? it's more expensive, no ? you have any pics &gt;?
Old Jun 28, 2005 | 10:09 AM
its larger and bolts right up without any modification...
thats why i was debating on selling my prelude mc and bb to get some from a DA to save me some headaches
Old Jun 28, 2005 | 05:22 PM
Rob.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracer228 &raquo;</TD></TR><TR><TD CLASS="quote">its larger and bolts right up without any modification...
thats why i was debating on selling my prelude mc and bb to get some from a DA to save me some headaches</TD></TR></TABLE>
LARGER ? It's 1" ?
all you have to do to the Prelude MC is bend 1 of the lines slightly... not a big deal.
Old Jun 29, 2005 | 04:59 AM
LARGER ? It's 1" ?
-i meant larger than the civic mc and bb, not the one from the prelude
Old Jun 29, 2005 | 05:09 AM
Cory man's Avatar
If you use the 90-91 Civic EX 15/16 m/c there is no brake line bending or booster swapping necessary. I have EX knuckles with the 10.2 inch integra calipers and rotors. Nice upgrade and its OEM.
Old Jun 29, 2005 | 07:57 AM
Chase's Avatar
Default Re: Prelude Master Cylinder Upgrade ! (Cory man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory man &raquo;</TD></TR><TR><TD CLASS="quote">If you use the 90-91 Civic EX 15/16 m/c there is no brake line bending or booster swapping necessary. I have EX knuckles with the 10.2 inch integra calipers and rotors. Nice upgrade and its OEM. </TD></TR></TABLE>
I went to the junkyard and found a EX sedan and got the MC and knuckles, and i alrady have front and rear DA integra brakes sittin in my garage. So i will be doin this soon
Old Jun 29, 2005 | 09:27 AM
crexer's Avatar
Default Re: Prelude Master Cylinder Upgrade ! (b16crxkid)
the only bending required for the prelude MC or the accord lxi MC can be done with your fingers and it is such a slight bend, no big deal it took me about 30 seconds. please dont use a torch or anything of the sort lol
Old Jun 29, 2005 | 10:07 AM
Default Re: Prelude Master Cylinder Upgrade ! (crexer)
good deal, then ill just use the prelude setup that i have... I was just afraid to crimp the line when i bend it and have to replace it
Old Jun 29, 2005 | 10:43 AM
*Boostwerks*'s Avatar
Exactly...and it's the same size. No bending of the lines needed.
Old Jun 29, 2005 | 12:24 PM
Rob.'s Avatar
Default Re: Prelude Master Cylinder Upgrade ! (Bryson)
I got my brand new OEM Nissin 1989 Prelude Master cylinder today. It's going on tomorrow.
Old Jun 29, 2005 | 12:58 PM
RapeV-8's Avatar
NISSAN PRELUDE???!!!WTF?
Old Jun 29, 2005 | 01:07 PM
crexer's Avatar
Default Re: (igotcrx)
not NISSAN, NISSIN its probably stamped on all your calipers, its the manufacturer of braking components. Let us know how easy this "bending" of 1 line is when you get through rob.
Old Jun 29, 2005 | 01:15 PM
turbotommy's Avatar
Default Re: (crexer)
i have this mod! ******* love it w/ my brembo's....no mush, just stop...
Old Jun 29, 2005 | 01:20 PM
hatchblack's Avatar
i currently have the 89 prelude master and brake booster in my 89 hatch. the one line that needs to be bent is very easy to bend with your hands. just bend slowly and carefully and you won't have a problem. the brake booster bolts directly in without any modification. it's just bigger, so it might be a little harder to move around to get it into the car. that was the only thing i had any trouble with. but it fits.
Old Jun 29, 2005 | 01:26 PM
N1ghtM0nkey's Avatar
Default Re: Prelude Master Cylinder Upgrade ! (hatchblack)
Just remember brake fluid is flammable, so don't use any kind of fire, spark, or any other heating technique...unless you'd like to see your car go up in flames.
Old Jun 29, 2005 | 01:43 PM
crxmrder's Avatar
i just up graded my breaks on my 88 hf and will the 89 prelude MC bolt up to mine as well.?
Old Jun 29, 2005 | 02:06 PM
kcjohnnyboy's Avatar
will it work for my 90 crx si with four wheel disc? if so, i prolly do that soon
Old Jun 29, 2005 | 04:46 PM
Rob.'s Avatar
Default Re: Prelude Master Cylinder Upgrade ! (kcjohnnyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy &raquo;</TD></TR><TR><TD CLASS="quote">will it work for my 90 crx si with four wheel disc? if so, i prolly do that soon </TD></TR></TABLE>
YEP ..NO PROBLEMO.. I am using it on my 1991 crx si... It'll bolt right up to any 1988-1991 civic/crx.
hatchblack, you didnt have to buy the prelude brake booster...
Old Jun 29, 2005 | 05:51 PM
JK_Motorsports's Avatar
I ran this on my dx with integra fronts and rears. Loved it until 2 Prelude MCs went bad on me. I'm just not sure if it was from not running the Prelude BB
Old Jun 29, 2005 | 05:55 PM
Rob.'s Avatar
Default Re: Prelude Master Cylinder Upgrade ! (bumblezc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumblezc &raquo;</TD></TR><TR><TD CLASS="quote">I ran this on my dx with integra fronts and rears. Loved it until 2 Prelude MCs went bad on me. I'm just not sure if it was from not running the Prelude BB</TD></TR></TABLE>
are you serious ?
this page I read says nothing about getting a prelude brake booster..I think the DX Booster is different from the Si..
Old Jun 29, 2005 | 06:20 PM
Rob.'s Avatar
Default Re: (crxmrder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxmrder &raquo;</TD></TR><TR><TD CLASS="quote">i just up graded my breaks on my 88 hf and will the 89 prelude MC bolt up to mine as well.?</TD></TR></TABLE>
you have an HF Brake booster... you might need to upgrade to an Si... or the Prelude BB...
