Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Rear Brake Pads...worth getting???
Old Jun 28, 2005 | 01:52 AM
h46it's Avatar
Default Rear Brake Pads...worth getting???
I was wondering do you think I'm going to get any benefits by upgrading the rears pads? Just that I'm ordering new fronts(Hawk HP+) should i just get HP+ for the rear too? Or just go for the OEM's?
Thanks everyone!
Old Jun 28, 2005 | 01:55 AM
TimeRacer's Avatar
Default Re: Rear Brake Pads...worth getting??? (h46it)
If you're going with HP+ just for the street use then you probably won't need to upgrade the rears. However just know that the more front bias that you have the more the car will push under braking. That said I'd probably get a set of cheap performance pads like the Axxis Ultimates or something for the rear.
Old Jun 28, 2005 | 01:58 AM
h46it's Avatar
Default Re: Rear Brake Pads...worth getting??? (TimeRacer)
Cool thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimeRacer &raquo;</TD></TR><TR><TD CLASS="quote">However just know that the more front bias that you have the more the car will push under braking.</TD></TR></TABLE>
So if i got pads that are less bias for the front and more bias towards the rear i'll get the car to turn a bit better under braking?
thanks again!
Old Jun 28, 2005 | 03:18 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h46it &raquo;</TD></TR><TR><TD CLASS="quote">So if i got pads that are less bias for the front and more bias towards the rear i'll get the car to turn a bit better under braking?</TD></TR></TABLE>
Judging by your way of thinking, I'm guessing you posted this in the wrong forum.
Old Jun 28, 2005 | 06:29 AM
nsxtasy's Avatar
H-T Order of Merit
My advice: Just do the front pads. Try it out with the OEM rear pads as is. It will probably be fine (especially since the HP+ is basically a street pad more than an all-out track pad). If you don't like it, you can always swap the rear pads later, but otherwise, you can wait till the rears need replacing, and then go for pads that match the front.
Old Jun 28, 2005 | 08:38 AM
h46it's Avatar
Default Re: Rear Brake Pads...worth getting??? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">My advice: Just do the front pads. Try it out with the OEM rear pads as is. It will probably be fine (especially since the HP+ is basically a street pad more than an all-out track pad). If you don't like it, you can always swap the rear pads later, but otherwise, you can wait till the rears need replacing, and then go for pads that match the front.</TD></TR></TABLE>
Sounds good!
schumi
28
Feb 11, 2008 06:24 AM
citrus3000psi
Jan 31, 2008 07:22 PM
Isaac
13
Jan 16, 2002 08:02 AM
