car won't start HHHEEELLLPPP
Old Jun 27, 2005 | 09:40 PM
91d15bvtec's Avatar
Default car won't start HHHEEELLLPPP
haha sorry no nudity. anyway my crx still won't start. no priming of the fuel pump. i took the main line at the rail off and no fuel came out after a few cranks. tried a new main relay. checked fuses and tried another ecu. still nothing. came home from work turned off. then tried to start and thought i was maybe out of gas. 2 gallons of fuel then no start. next morning starts right up. then after day in the sun no start. tried new ecu and main relay still nothing.
any suggestions appreciated.
Old Jun 27, 2005 | 09:46 PM
Ruthless671's Avatar
Default Re: car won't start HHHEEELLLPPP (91d15bvtec)
Maybe your stock fuel pump is going out? I had the same problem with my 88 crx, after all the headaches, i found out if was the main relay under the driver dash. Good luck though.
Old Jun 28, 2005 | 11:19 AM
91d15bvtec's Avatar
Default Re: car won't start HHHEEELLLPPP (Ruthless801)
although i checked my kill switch before it ended up being the reason why my car wouldn't start.
thanks for your help
Old Jun 28, 2005 | 01:27 PM
NikoZai's Avatar
If your fuel pump isn't priming it's either the pump itself, the main relay, or the battery.
Check electrical connections to verify it's not the wiring or a blown fuse prior to checking the pump.
You might want to follow the troubleshooting guides in the manual.
http://www.norcalcrx.org/library/ - Manuals on the left.
Old Jun 28, 2005 | 01:42 PM
vtecn8ive's Avatar
Default Re: car won't start HHHEEELLLPPP (NikoZai)
is it turning over at all?
Hugsnkisses01369
Aug 18, 2006 02:46 PM
91d15bvtec
Jun 29, 2005 05:08 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
AgentJam
Aug 15, 2004 03:07 PM
areyouahobo
Jul 3, 2003 05:39 AM
