BlackTrax Intake Manifold
Hey, i have been searching but have not found a dyno for a BTP IM. anyone know where i can find one? or anyone have one they can post up? i know they have one on their site, but i wanna know what ur gains r on ur setups?
I ran a dyno test for them a month or two ago, here's the results:
https://honda-tech.com/zerothread?id=1250755
Provides good gains from around 4500 rpm on up, lose some torque down low as expected.
have you retuned recently? you made ok power, but you should definetly have more. i dont think your exhaust is the problem, 2.5" is enough for an all motor setup. i made 195/150 with crower 2's, dc header and a worldsport exhaust... which i believe, has only 2.25" piping.
My current piping is 60mm, so bumping up to 2.5" should help it breath a little better. I'm still trying to figure things out but I think my PCV system hasn't been working properly which may of held me back. After fixing some leaks I hooked my catch can back up (haven't had it hooked up since it didn't have a baffle & was letting oil go straight through it) and my idle rpms are now 7-900 rpms higher, and my car seems much more responsive now. I'm guessing the catch can has freed things up a bit since now my torque is where it ought to be (140 is too low) and thus my power is up as well. I'll redyno it after I get an new exhaust and see how things are.
baulum
12
Jan 18, 2010 07:49 PM
Turbo-charged
Feb 18, 2006 02:49 AM
SIINSI
Sep 2, 2002 06:33 PM
se93
Sep 1, 2002 09:32 PM
