Tach cuts in and out..? wtf
Old Jun 27, 2005 | 07:51 PM
JDMKid71's Avatar
Default Tach cuts in and out..? wtf
Ok this is getting kinda annoying.. and i dont know if its a wireing problem.. or a ECU problem.. or what it is.. maybe a bad sensor..? what is happening is my tach will be working perfectly fine.. and when i slam on the gas and make it move faster it seems to get held up, i can hear the engine to continue revving up but my tac doesnt move then it will jump real real fast to the current RPM...? it only seems to happen when im trying to "race" so i dont know what it is..? anyone else have a similar problem..? any help/sugestions would be helpfull!! thanks!
Old Jun 27, 2005 | 09:02 PM
eXcelonTypeR's Avatar
Default Re: Tach cuts in and out..? wtf (JDMKid71)
I had a similar problem, but it also included random power loss.....the problem was the four-wire ground connector (im pretty sure its the wiring harness grounds) that is on the thermostat, mine was loose, tightened the bolt down problem gone, try that
Old Jun 27, 2005 | 09:32 PM
snoozinhatch98's Avatar
Default Re: Tach cuts in and out..? wtf (eXcelonTypeR)
I had the same problem too. mine just turned out to be a loose connection on the back of the gauge cluster
Old Jun 27, 2005 | 09:45 PM
JDMKid71's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eXcelonTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problem, but it also included random power loss.....the problem was the four-wire ground connector (im pretty sure its the wiring harness grounds) that is on the thermostat, mine was loose, tightened the bolt down problem gone, try that</TD></TR></TABLE>
Yeah i have noticed a significant decreas in power also... i thought maybe it was just the 95-100 degree temps were having right now.. lol il check all grounds.. thanks! (sorry for spelling im in a hurry)
Old Jun 27, 2005 | 09:55 PM
Biggest thing to remember when you have electrical problems is:
1. Check all connections
2. Check grounds
Most common problems with me lol, guess i mess around with the electrical too much
JasonST
Jan 7, 2007 07:17 AM
Nihilus
Dec 18, 2005 01:28 AM
Nataku
Dec 3, 2005 07:12 PM
sir168
Mar 15, 2004 06:09 PM
PoWeRBaN_PaNdA
Aug 28, 2002 02:48 PM
